Hi Chris,
I was onto getting another pulley, then realized removing the pulley isn't that hard with the right tool, but I reckon it's better to have another pulley so I can swap the alternator without having to stuff around too much.
I fabricated the spacers for the pulley & the alternator mounting bolt, both by myself. It wasn't that hard, and wasn't that much of "fabrication" either.(I like the word,
Yeah, it all lined up pretty well, only thing is that the alternator is a bit of PITA, 'cos I managed to get a one covered with transmission oil damage. It's working fine, just bit too much crap inside.
From what I see, I can't get the wires wrong, 'cos it's exactly like the original one. The socket is the same for the trigger wire and the sense wire(
do tell me if that's not the case). Then Battery wire is the same way,except I need a bigger lug to fit the wire(I have to do all new 100A battery wire+fuse anyway).
Earth wire is the same as well. So, I'm not sure how you got it mixed up. Probably the one you got hold of is bit different on rear connections?
I'm pretty sure you're lucky to not to cook anything inside the alternator when you connected the earth wire to the B+. I guess since the short circuit happens before the alternator internal parts, you would've had just enough time to disconnect it before any damage.
I got all the pictures and details of the little project. I'll post it as a thread soon.
