1st December 2015, 12:01 PM
#11
Go the whole hog.
If the old body is suffering rust bad in the roof good chance rust has bitten elsewhere.
Rust proofing in and out .
swapping the body, yes it's a big job so why not spend a little more time doing it better.
You'll be happy knowing that you did it while its apart, later on after you've put it all together is a pita.
Hey, why not sound/heat proof the fire wall while its apart, it's the perfect time.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
1st December 2015 12:01 PM
17th January 2016, 08:54 AM
#12
I'm in the middle of doing a cab swap not as easy as I was hoping for due to time issues but I'll get there eventually
17th January 2016, 10:55 AM
#13
Yep. Swap the body. You will have a good chance to look the car through at the same time.
Thanks a lot
Rafal
Nissan Patrol Y60 (GQ) TD42
Land Rover 101 Forward Control 300Tdi
Few driftcars and a buggy
17th January 2016, 11:28 AM
#14
Yeah that's why I'm doing a full rebuild from ground up get it back to pristine condition
