11th November 2015, 08:40 PM
Help with light bar wiring
Hey guys,
Scratching my head a bit here after trying to wire up my new light bar. There is already spotlights wired up so I have piggy backed off the high beam wire going to the relay for them. Spotlights still work but not getting any light through the lightbar at all...
I'm sure I am missing something very stupid, but given that its 43 degrees here atm I'm hoping someone on here could point me in the right direction rather than cooking myself all day trying different wires etc.
Heres a diagram of how its wired up currently, any help would be greatly appreciated!
GQ Patrol, TD42 NA, 33's, Snorkel, 2" inch lift, Dual Batteries, Roof Rack, Awning... Many more to come
11th November 2015 08:40 PM
11th November 2015, 08:49 PM
first things I would check................
put power to LED bar, and make sure it works
then
power to the switch from other relay
power from Aux battery to Fuse Block
power from fuse Block to relay
if all good
swap relay with another (I have brought a pkt of 10 relays - and only 6 worked)
ummmmmm
when checking if it was working, you DID have the high beam on..................... so power could get to the switch................
11th November 2015, 09:06 PM
I am he, fear me
Is there 12 volts at pin 87?
If so are you sure you have the Light Bar polarity the correct way?
If not is the -ve of the Aux battery and the Main Battery common?
11th November 2015, 09:43 PM
Bigcol
then
if all good
ummmmmm
Haha yes I did wonder whether I had full beams on... But I did, tried different combo's of lights. Will test the things you suggested cheers mate!
Is the wiring in diagram correct though? Hopefully its just a dud relay!
11th November 2015, 09:47 PM
the evil twin
Good thinking mate! I wasn't sure which way the plug polarity was, because it came with a sort of anderson plug fitting.
Both batteries are earthed to chassis, and run through a DC to DC charger.
11th November 2015, 09:50 PM
I am he, fear me
If the battery earths are common yes, the wiring will work, if they aren't then no it won't...
Again, if you have 12 volts at pin 87 then check the polarity of the Bar
If you don't have a meter jump the wire for pin 87 straight to battery +Ve
11th November 2015, 10:03 PM
the evil twin
Thanks for your help mate I will check them after work tomorrow!
12th November 2015, 09:56 AM
#8
Yo Ash what size light bar are you trying to wire up???
12th November 2015, 10:45 AM
#9
Just a thought but have you piggy backed the new switch using the wire
from the head light high beam to original switch Then run a wire to new solenoid.
I think if you use the other wire it wont work If that makes sence
12th November 2015, 04:55 PM
#10
threedogs
Its a 120W 22" bar from 4wdsupacentre...
