Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Min brake pad thickness
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    What is the min safe thickness of your pads before you need to change them?
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
    The master farter
    mudski's Avatar
    461 Post(s)
    Before the metal backing plate. Lol. Id prolly change them when theres a couple of mm left.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Make sure you check all over - they sometimes can have a 1mm difference between leading and trailing edge wear. I usually have a spare set I buy when on special and keep in the shed. Always going to have to do them sometime.
    Oct 2013
    Adelaide
    5 Post(s)
    So 3 or 4 mm still ok?
    "GO YOU CROWS"
  6. #5
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by Chubba View Post
    Hard to say. Depending on pad compund and how fast they wear. Id just buy some new pads for spare and keep an eye on them if you want to get the most out of the pads.
  7. #6
    Oct 2013
    Adelaide
    5 Post(s)
    Cheers. Mate They are a hard compound. So I'll keep monitoring.
    "GO YOU CROWS"
  8. #7
    They are cheap enough to change unless your ABS
  9. #8
    330 Post(s)
    There is a return on the end of the mounting plate that is designed to hit the disk and make a horrible noise when your pads are low way before they run out but enough that you want to get on it ASAP.
  10. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    What about disc thickness??
    North brissy
    Quote Originally Posted by biggqwesty View Post
    Should be stamped on the disc. Min thickness xxmm
  12. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (7th November 2015)
