And I've lost faith in the idea of it being under the bonnet now, theres not really any room to mount it now ive had a good look. I might build a compartment in the rear for it and the aux battery, dunno yet.
There is a simple solution if you want to use an auxiliary battery (12v) to run the compressor. A redarc BCDC 1240 will accept 24v to charge a 12v battery. (It will also enable you to connect solar panel(s) to charge the aux battery without needing to buy a another solar regulator if you want to do that down the track).
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
Thanks for that cuppa, I always thought that you couldn't earth a 12v battery to a 24v earth. Obviously its doable haha, I might need to brush up on my electrical skills
