29th October 2015, 05:08 PM
#11
what brand tyres have you fitted, are they an all terrain or mud pattern style
29th October 2015 05:08 PM
29th October 2015, 05:28 PM
#12
Patrol Guru
Do you know if the Prado has traction control or a locker? What sort of terrain did you get stuck in? Where you lifting you wheels? A mate has a 120 Prado and without his rear arb diff lock he has trouble keeping up with gu patrols on difficult terrain. So if you can describe the terrain and what mods the Prado has we might be be able to nut this out. Also, if the Prado driver is experienced he might be picking the correct line which makes a huge difference.
2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
29th October 2015, 09:06 PM
#13
The prado had all the bells and whistles so I spose traction control would be one of them and the terrane was rocky loose creeks banks. The Mav has 4.2L petrol carby with standard suspension. My tyres are desert duellers
29th October 2015, 10:02 PM
#14
You really need to tell us what was stopping you from going anywhere that your mate did. Was it wheel spin? Car bottoming out? Motor bogging bown? What sort of terrain did the Playdo go where you couldn't?
I know for a fact that even stock Patrols can get you most places. We've taken out members with stock cars and its even surprised the owners how well the car went.
A lot of cases, not saying its your case, its driver ability.
The Following User Says Thank You to mudski For This Useful Post:
BigRAWesty (30th October 2015)
29th October 2015, 10:06 PM
#15
Have you got much 4wding experience under your belt dancer? I reckon with a good amount of skill and some 33" tyres you'd out drive any bell or whistle that Mr Toyota put there lol
tappin from tassie
Hello from Under Down Under!
29th October 2015, 10:10 PM
#16
Patrol Guru
Sounds like the Prado has traction control if its fully loaded with all the gear. With the Patrol you need to run 22-25psi (if you had not reduced pressure) in the tyres in the terrain you mentioned and you get a lot less wheel spin/slip which helps the LSD work. The LSD will not work if one side loses all traction so that may have been happening. Depending on the kms, the LSD could also be worn as it relies on clutch packs to work. The option would then be to tighten/rebuild the LSD or replace it with a locker. The locker sends power to both sides (1:1) so continues to work as long as there is traction on one of the tyres.
29th October 2015, 10:39 PM
#17
mudski
A prado with a decent set of tyres and traction control will go along way. Especially if an auto, you just cant beat an auto for slow, low traction stuff. (Yes downhills maybe different).
29th October 2015, 11:38 PM
#18
Patrol Guru
Hay Dancing Chicken. I notice in your intro that the old girl has done 400000kms
I had an old Maverick myself a few years ago that had done about 380000kms and I can tell you that the LSD in that one was just about shot. The LSD (rear diff) can and do wear and at 400000ks yours is probably in need of some TLC. A tired LSD would not be helping your cause at all. It would be worth getting it looked at.
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
30th October 2015, 01:09 AM
#19
Chubba
See now that's weird.. Mine has 520 thou on it and still chirps when turning under power and pretty much any gear in low range.. must be a good one..
I'd purely put it down to experience..
You have one of the best 4x4's on the market.. with a bit of know how and practice mate you'll leave him for dead..
As mentioned above I would have dropped tyres to 25psi. Not only will it soften the ride but you'll increase the traction 10 fold.. the tyre will mould to the rocks instead of trying to sit on top of them..
Next one (and I have met a few who didn't know this one) the old Gq's have manual locking hubs.. you have to get out and engage them for them to work.
As much as a pain this can be I personally wouldn't change it.. they are a bloody strong hub..
Next is gear selection..
Being a petrol you may need to use the rpm a bit more?? I'm unsure on this one I'm a deisel man.. but when we did the vic high country it was low range 1st and accosionally 2nd on the steep sections.. but I run 33" tyres so I loose a bit of gearing compared to a 31" tyre...
Tyres for doing that sorta terain I don't think will be a huge influence but a good set of all terain tyres are a good pick..
And probably the most important tip is pick your line.
As a beginner is suggest pick the flatest most direct route.. trying to mount large rocks etc adds difficulty and if you can give it a miss I'd say miss it go around it.
Once you get a feel for the car and some experience under the belt then you start pushing it.. I'm still learning. Been off roading since I was young with my olds. .
But. Don't get to beat up about it either.. your in a car that's possible 15-20 years older then your mates.. sometimes the old busses just get out powered..
that's when a little bit of no fear plays a part and you push that a bit harder.. 😈
Enjoy the ride mate..
The Following User Says Thank You to BigRAWesty For This Useful Post:
Stropp (30th October 2015)
30th October 2015, 07:28 AM
#20
You havent said if you selected either H4WD or L4WD have you, from inside the Patrol??
The Following User Says Thank You to threedogs For This Useful Post:
