3rd April 2012, 07:50 PM
#171
The Following User Says Thank You to msw21 For This Useful Post:
Forced Offroad (10th April 2012)
3rd April 2012 07:50 PM
7th April 2012, 09:52 AM
#172
great build so far mate. lookin forward to seeing this thing on the dirt. ( probably not as much as you looking forward to it though :P )
ozz
The Following User Says Thank You to ozzyboy For This Useful Post:
7th April 2012, 10:18 AM
#173
The Following User Says Thank You to Alan GQpatrol For This Useful Post:
10th April 2012, 10:36 PM
#174
Cheers guy's
NOt much more done except the rear wall to the truck which a big thing, as all i need to do is a bit of grinding as i have changed my mind again
More gear ordered
Tigerz11 awning with the silly prices at the moment
Rhino platform racks with a cool little mod with one http://www.rhinorack.com.au/AccSubCa...-Racks_74.aspx
12th April 2012, 09:46 PM
#175
Bit of detailing,
Fired up the engine for a good hour tonight, and gave it a little service as it been sitting still for nearly 2 years. Forgot how nice it sounds.
New battery,new hight torque starter motor,new ignition Module has been done over the past year. So I hope I can get from A to B,C,D,E,F and G I venture further. Always seem to break down in bad areas, but always been lucky to get it started.
19th April 2012, 06:58 PM
#176
The Following 3 Users Say Thank You to Forced Offroad For This Useful Post:
Clunk (21st April 2012), growler2058 (19th April 2012), NissanGQ4.2 (19th April 2012)
19th April 2012, 07:16 PM
#177
Haha like it...is that brake/ tail switched?
Or a switched fog light?
Nothing wrong with thinking outside the box.
Slip the light off, pass it and wiring through the rim and easy access to the spare wheel as required.(if ever)
Dave
99 GU 2.8 TD
Brisvegas, QLD
The Following User Says Thank You to robbo0001 For This Useful Post:
Forced Offroad (19th April 2012)
19th April 2012, 07:48 PM
#178
Its both mate tail and brake.
The wiring will be all concealed and hidden away. This was the test run getting the loom right.
21st April 2012, 10:04 PM
#179
All wired up for the rear light set up.. Hopefully this will keep the DOT happy with more than enough brake/tail and indicator lights.
passenger side is not in as I cant find the bloody screws, Also the rear flood light in hooked up to the reverse power. So when its in revers it will light up the bush.
The Following User Says Thank You to Forced Offroad For This Useful Post:
25th April 2012, 05:44 PM
#180
Bit greedy,but have come up with a easy mounting bracket if you own a iPad . Will post build on it when I start.
Should stop buying toys and finish the freakin truck.
growler2058 (25th April 2012)
