24th September 2018, 08:42 PM
Limp mode
I posted a thread on the general discussions page,new at this,My 2004 GU AUTO 4.8 PETROL PATROL keeps going into LIMP MODE when towing our caravan.oil has been changed filter cleaned,STILL doing it,any help would be much appreciated.Thank's Wazza.
24th September 2018 08:42 PM
24th September 2018, 09:19 PM
Dribble Master
Getting any engine warnings lights come on?
Does it only happen when towing the van?
Faulty O2 and/or crank angle sensors can cause this in a non towing situation.
25th September 2018, 03:17 AM
Hi mate,
If you have fitted a dawes and Needle Valve, and got read of the ECU control/ Solenoid, Limp mode can also be due to turbo pressure going a bit too high with the extra load/extra pressuve on the throttle, whilsrt the revs are too low. Turbo pressure going up means more air being swallowed by admission and therefore MAF going up...
A bad MAF-Revs couple of values, and you get the limp.
25th September 2018, 07:16 AM
phdv61
Hi mate,
The op has a 4.8. Not the 3ltr bud...
As for the issue at hand. The first thing I would do is plug a scan tool in and see what codes come up and work from there.
Sent from my crapPhone using Tapatalk
25th September 2018, 08:47 AM
Thanks guys for your input,we have towed this van for ten years with no problem's.This year removed LPG,fitted LR petrol tank,Beau desert exhaust with extractors, new 02 sensors.NOW we have LIMP problem's.The GU run's like a dream,without the VAN on.Drive 500k with Van on ,stop for fuel ''lots of it'' drive off bang into LIMP.Had codes checked,slow brake solenoid showed up. Very strange i think.?
