Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Dropping Oil Pressure - Yes I know.....
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    I see 90 when its hot...so that ia way better than 1/2 way all the time. I will certainly keep an eye on both.
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
    461 Post(s)
    Recieved my replacement oil, pressure switch last week from Redarc. Fitted and all is good for now. Although i do question its accuracy on oil pressure and water temp.
    AJTich (12th December 2015)
  5. #23
    Expert Astro's Avatar
    Apr 2011
    Macksville
    I've gone through 2 oil pressure senders on my redarcs, about to order a 3rd. The sender must be a poor design to keep failing like they do.
  6. #24
    Oct 2013
    Andrews Farm
    Yep, now my sender unit is stuffed. Oh well, 4 years is better than most people seem to get. $105 is a shock to the hip pocket but.
    Hmm, and until it failed, using the 10W40 kept oil pressure and reviewing gauge accuracy per my older posts, it stays around 70 when really hot, and on idle drops to 25-30 so seems to all be good.
    Bloody REDARC..they know how to charge.
    AJTich
