Results 11 to 20 of 24
Thread: Dropping Oil Pressure - Yes I know.....
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    At least living in Adelaide, so easier to get to them..pain to get out of truck though. Might ask them for a replacement sender for mine...
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
    Oct 2013
    Andrews Farm
    Thanks Hodgey, Will ask the REDARC guy at the Show on the weekend...see how to get a replacemetn sender.
    AJTich
  4. #13
    465 Post(s)
    Quote Originally Posted by AJTich View Post
    I spoke with Matthew at Redarc. So if you ring them, ask for Matthew. He's got my our conversation we had on file....
    With any luck i get my car back tomorrow. And i will test the sender unit tomorrow...
    AJTich (21st October 2015)
  6. #14
    Oct 2013
    Andrews Farm
    Hey Hodgey, yes it is scary...
    Today my EGT/Boost gauge Boost went to MAX..but after a little while came back to reading correctly.
    Starting to wonder about the previous mechanic who fitted them and do i need to redo the whole loom to close that out.
    AJTich
  7. #15
    465 Post(s)
    I havent tested my sender unit yet. But i had a look at it and its wet with oil where the wires come out. So im assuming its fubar. If i have time tomorrow i will remove the gauge and run a dmm on the sender wires to see if theres voltage.
  8. #16
    465 Post(s)
    Just thought I'd touch up on this topic again. I have tested my sender unit and there is no voltage change at all when the car is started. So I guess the sender is fubar. Time to ring Redarc.
    AJTich (10th November 2015)
  10. #17
    Oct 2013
    Andrews Farm
    I dis the reset all on the gauge, changed oil to 15w and did an engine oil flush at same timw and ao far seema to hold 》25 when warm. Bloody gauges...
    AJTich
  11. The Following User Says Thank You to AJTich For This Useful Post:
    mudski (10th November 2015)
  12. #18
    465 Post(s)
    Yeah i kinda wish i never had them (oil pressure and water temp). I keep on looking at them for no need. My water temps fluctuate a lot but the oem gauge doesn't move. I might even get rid of it and put a clock or something there. Lol.
  13. #19
    Oct 2013
    Andrews Farm
    Water temp scared me because the Nissan one hides behind driver's arm...and had a temp rise climbing thru the Hysen Tunnels... So fitted that one...and figured oil pressure to keep oil level checked..
    AJTich
  14. #20
    465 Post(s)
    Yeah im questioning the accuracy of the Redarc water temp gauge too. Ive seen it hit 110c on the Redarc gauge, yet the oem gauge doesn't go any higher. I know the oem gauge works though, as on our Dargo trip when we hit the black top on the way back from a day trip, it was a real long down hill run, it was bloody cold outside, both gauges dropped down.
