Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: How to install a nutsert without using the tooling
    581 Post(s)
    A nutsert works on the same principal as a pop rivet.
    The base of the nutsert under the panel your putting it in expands under pressure and locks it to the object.
    Nutserts are great to use because they have a thread inside to bolt things to without needing to get underneath the object and try to hold a nut on, etc.
    Perfect for fixing things to vehicle such as snorkels, etc because you don't have to remove the trim inside the A pillar or try to get in underneath the engine bay, etc.
    This isn't the funnest job in the world and can take some time but if your doing half a dozen nutserts then this method works without buying special tooling.
    Based on a 10mm nutsert.
    1. Drill your 10mm hole into the object to nutsert to.
    2. Using a 10mm bolt, screw a nut on the thread of the bolt followed by a washer hand screw the bolt through the middle of the nutsert threads until it comes out the other side.
    3. Put the nutert with the bolt screwed in, into the hole.
    4. Using vise grips or a spanner hold the top of the bolt head.
    5. Using a spanner start to tighten the nut (clockwise direction) This pulls the nutsert up and expands the nutsert which will hug underneath the panel and lock it in......When it gets extremely hard to rotate the nut then thats it.
    See below for rough diagram...
  2. The Following 40 Users Say Thank You to AB For This Useful Post:
    @GUte (1st October 2013), AussieRoadHammer (5th May 2011), Ben-e-boy (4th April 2011), Bidja (29th January 2019), big_fletch (16th May 2011), Bob (4th April 2011), Bruza (13th May 2011), brw1994 (8th January 2013), canuck (15th December 2011), Dhuck (4th April 2011), Finly Owner (4th April 2011), FNqGu04 (15th January 2017), Goldifox (18th November 2013), GUtsy ute (10th April 2011), janderson (16th September 2013), JoeG (17th May 2011), Kast (9th August 2013), Majestic (23rd October 2014), Maxhead (4th April 2011), mjr350 (30th April 2015), Muttley (29th July 2013), my third 256 (5th April 2011), NissanGQ4.2 (4th April 2011), NotTortoise (9th November 2015), oxmann (21st November 2012), Parksy (7th August 2014), patch697 (4th April 2011), Plasnart (4th April 2011), Rip'n'Shred (15th March 2012), ripper (16th May 2011), Robo (3rd March 2012), RustyR (14th September 2011), sibbles (6th January 2012), Sir Roofy (4th April 2011), Snafu (18th January 2012), Tank (9th June 2012), taslucas (17th December 2011), the ferret (4th April 2011), twisty (15th November 2011), wannabeturboed (6th October 2014)
    Banned
    These thing leave a nice finish & I could go spastic with a box of them.....lolol
    Thanks AB bloody good post.
    581 Post(s)
    Forgot to mention...
    On the outside of the nutsert there are grooves which are suppose to bite into the metal and to stop it from spinning.
    Sometimes the nutsert can spin when you are trying to do the nut up on the bolt which makes me angry...lol
    If this happens then you need to stop it from spinning whilst you do the nut up so try doing the following.
    1. Hold the bolt on an angle to try and force it to lock in to the side of the panel
    2. Take the nustert and bolt out....Hold the bottom edge of the nutsert with visegrips and do a few rotations to expand the nutsert a little bit and try again...This will make the nutsert a wee bit bigger and should bite in better....You may have to hammer the nutsert back into the hole again too.
  6. The Following 4 Users Say Thank You to AB For This Useful Post:
    Bidja (29th January 2019), Parksy (7th August 2014), ripper (16th May 2011), the ferret (4th April 2011)
  7. #4
    Banned
    You might also try using 2 washers with a dab of grease in between them to give it a slip point.......... Don't know if it would work but worth a try.
  8. The Following 2 Users Say Thank You to patch697 For This Useful Post:
    AB (4th April 2011), Finly Owner (4th April 2011)
  9. #5
    581 Post(s)
    Quote Originally Posted by patch697 View Post
    Yes mate that would work on ensuring the bolt can pull up but I was referring to the actual nutsert spinning inside the substrate you are trying to lock it in to.
    They sometimes spin whilst your are trying to force the bolt up when spinning the nut so you may have to reef the bolt to one side or take it out and expand it a bit and ram it back in to the hole and start again.
  10. #6
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Wow...what a neat little beauty.
    Thanks for sharing mate
    ________________________
    ______ 2017 D-Max _______
  11. #7
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    and are these nutserts at the local hardware or bunnings ?
  12. #8
    581 Post(s)
    Quote Originally Posted by roofy View Post
    No Bunnings will not supply them...I highly doubht it anyway.
    I would be going to a proper nuts and bolts company, maybe Mitre 10 but doubht it also.
    Ebay Roofy ----> http://shop.ebay.com.au/?_from=R40&_...All-Categories
  13. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (5th April 2011)
  14. #9
    581 Post(s)
    Don't forget to get velcro, foam or some kind of padding between the car and the bracket too.
  15. #10
    TRAFALGAR VIC
    35 Post(s)
    thanks mate will do
