20th March 2012, 09:43 PM
#31
Helpfull stuff thanks mate
20th March 2012 09:43 PM
24th April 2012, 12:34 PM
#32
17th May 2012, 04:51 AM
#33
great post, do you know an online seller that ships overseas, or better european seller
17th May 2012, 05:38 AM
#34
Banned
sibbles
eBay is your friend my friend!! lol
You can buy the tool and the nutserts themselves on eBay mate.
The Following User Says Thank You to Bigrig For This Useful Post:
9th June 2012, 06:16 PM
#35
this is realy clever we have nutsert guns at work n all sizes but iv never seen this done without the gun
handy for when the gun breaks
8th July 2012, 11:51 PM
#36
Heres another good resource for how to fit nutsets without a tool
http://www.carolinarovers.info/croc-...wn-rivnut-tool
20th August 2012, 07:46 PM
#37
Wow I never thought of that thanks mate
10th August 2013, 06:12 AM
#38
The Following 2 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
AB (10th August 2013), GQtdauto (29th January 2019)
29th January 2019, 09:44 PM
#39
AB
A nutsert works on the same principal as a pop rivet.
The base of the nutsert under the panel your putting it in expands under pressure and locks it to the object.
Nutserts are great to use because they have a thread inside to bolt things to without needing to get underneath the object and try to hold a nut on, etc.
Perfect for fixing things to vehicle such as snorkels, etc because you don't have to remove the trim inside the A pillar or try to get in underneath the engine bay, etc.
This isn't the funnest job in the world and can take some time but if your doing half a dozen nutserts then this method works without buying special tooling.
Based on a 10mm nutsert.
- Drill your 10mm hole into the object to nutsert to.
- Using a 10mm bolt, screw a nut on the thread of the bolt followed by a washer hand screw the bolt through the middle of the nutsert threads until it comes out the other side.
- Put the nutert with the bolt screwed in, into the hole.
- Using vise grips or a spanner hold the top of the bolt head.
- Using a spanner start to tighten the nut (clockwise direction) This pulls the nutsert up and expands the nutsert which will hug underneath the panel and lock it in......When it gets extremely hard to rotate the nut then thats it.
See below for rough diagram...
This thread is worth a bump. Thanks Andy
Did a google for nutsert fasteners for the install of my new 4" snorkel and this came up.
Will give it a go tomorrow.
The Following 2 Users Say Thank You to Bidja For This Useful Post:
AB (30th January 2019), GQtdauto (29th January 2019)
30th January 2019, 12:04 AM
#40
I am he, fear me
The "nut, bolt and a couple of washers" works well for the most part and is really handy if you don't have clearance for a Nutsert Tool Head (or Rivnut if one prefers).
I tend to use a Nutsert Tool most of the time tho, esp on stainless... worth having of you use Nutserts regularly, not so much if you only do a couple on rare occasions.
