6th October 2015, 08:29 AM
#11
I think that with 290k kms the trans should be considered as being in the latter part of its life. Even fitting shift kits, etc can't make up for the inevitable larger tolerances the clutch packs would now have. That's just due to typical normal wear in its lifetime.
That doesn't mean that it won't last quite a bit longer if it's looked after with good fluid and temps and driven with the care that older transmissions require..
I would still drop the pan and inspect the magnet, wash out the strainer and flush it all with synthetic fluid. Castrol TransMax Z is one of the better fluids but a more cost effective (which I'm now using) is the Nulon Multi-vehicle synthetic. You can get it in 20 litre drums.
John
6th October 2015 08:29 AM
6th October 2015, 01:35 PM
#12
grunta11
Hi Tucker trucker,
just so i understand you correct.... you used to push 95 before the rebuild and now your lucky to break 85.......was it your engine or your trans your refering to there?
either way thats bloody good news!........
appreciate you taking the time for input.
No worries mate, it was the trans. Shouldve been more clear lol. When really powering it and loading it (especially in OD) it would easily break the 100 mark. Highway temps and general use would push their way to about 95. But now I can load her up on the hills and I'm lucky if it breaks 85.
Cheers, Dylan.
6th October 2015, 01:38 PM
#13
jff45
Haha, when my trans spat the dummy I wasnt too educated in towing with autos - I'm amazed it took four years for it to happen now..... costly lesson to learn.
7th October 2015, 11:40 PM
#14
tuckertrucker
Cheers, Dylan.
Hey TuckerT
What rpms does yours sit at 100 klicks cruise?
Mine with new 33`s at an indicated 100 is just under 2000 rpm. My diff is in possible need of a new crown wheel/pinion set and was thinking of maybe i should consider a ratio swap from 3.9 to 4.1 to keep her in the ideal cruise rev range - especially if I'm towing the camper trailer and a car load of gear.
Its not yet turbo`d - thats a near future mod.
i realise the front has to change too,.
8th October 2015, 12:23 AM
#15
jff45
Thats pretty sound advice jff, cheers.
