4th October 2015, 01:14 AM
Saggy rear towing camper trailer, remedies.
G'day folks,
We have just returned from trip through The Kimberley and Pilbara towing a Pioneer Argyle camper trailer. The rear of the Patrol was a bit saggy due to the extra weight of the camper.
Would the easiest/cheapest fix be Poly Air bags in the rear springs or more heavy duty springs and shock absorbers? The Patrol does not normally have a heavy load unless we are off to the outback.
If possible I would do the work myself.
Michael
2008 GU DX Auto, dual batteries, Safari snorkel, Warn winch. Engine standard CRD 3L
4th October 2015 01:14 AM
4th October 2015, 07:30 AM
I would go the coils, other may go the air bags
micknor51 (4th October 2015)
4th October 2015, 09:42 AM
i have Poly Air bags in the rear springs and can adjust hight for boat, trailer and caravan because of the different weights
OH LEATHER IS NICE
4th October 2015, 12:00 PM
I am he, fear me
Don't go the airbags
The Towball weight of the Argyle should be 80 to 120 Kg (the Tare is only 800).
A Patrol shouldn't even notice that... so if you have got the "Dog with Worms dragging its butt" syndrome your suspension is shot.
I would just fix the suspension.
No point fitting airbags to a worn out suspension and with that load on a good suspension you won't ever use the airbags.
My prev camper was almost double the weight of your Argyle and the CRD Wagon I had at the time was chockers with draw system, fridge, Drop slide etc and that went gangbusters
I have airbags on my Ute which has a tray with max legal overhang and tow a 2 ton Van.
Apart from the 5 PSI I keep in there to keep them inflated they don't need to be adjusted until I have a very significant load
The Following 3 Users Say Thank You to the evil twin For This Useful Post:
Bigcol (4th October 2015), gaddy (22nd December 2015), micknor51 (4th October 2015)
4th October 2015, 01:42 PM
I agree with ET
if its dragging its bum............
new springs and shockies
air bags are good, but wont fix an existing problem, only help keep a problem away on good suspension
The Following User Says Thank You to Bigcol For This Useful Post:
4th October 2015, 02:37 PM
I did shocks, springs and poly airs. Careful how heavy you go as the ride can turn to crap if you go too heavy.
The Following User Says Thank You to Chimo For This Useful Post:
4th October 2015, 02:57 PM
As mentioned - springs will be the problem and airbags won't help.
Your shocks may still be perfectly fine, but should be checked anyway after a good long trip like that.
I just changed out all my coils, and adjusted my shocks (again). Sag is gone, ride height is back, and rebound is much better. I have Koni 88 series shocks that adjust up to just shy of three full turns (from memory). I now have them at two turns of adjustment (up from one turn) and it has made a huge difference to rebound.
With a load in the back of my wagon that includes drawers, tools, fridge, aux battery etc. etc. I went with the 500kg constant rated King Springs and found that it suits nicely what I do. I also tow a boat that is heavier than your Pioneer would be, and now it sits really nicely. Like ET, I also have the airbags, but only have 5-6psi in them to prevent pinching.
The Following User Says Thank You to FNQGU For This Useful Post:
4th October 2015, 03:55 PM
#8
Patrol Guru
I would go the new springs as well.
The Following User Says Thank You to blocko05 For This Useful Post:
4th October 2015, 06:40 PM
#9
Thanks for the info fellas. I will go with the springs and check out the shocks.
Do you have any particular recommendations on springs and shocks?
Michael
9th October 2015, 11:40 AM
#10
Tower braces would be a smart idea too while your doing the springs.... Get under there with a light and check the existing towers for any cracks. Common issue with Patrols to crack when used under load...
The Following 2 Users Say Thank You to mudski For This Useful Post:
micknor51 (10th October 2015), mudnut (22nd December 2015)
