Results 11 to 20 of 21
Thread: Help to identify thingy on 2006 4.2 GU
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Makka from our local WA club is pretty good with lectricks mate. Might be worth a PM.
  2. The Following User Says Thank You to 4bye4 For This Useful Post:
    Woof (29th September 2015)
    W.A. (wandering aust)
    Quote Originally Posted by Tuppa View Post
    Thanks everyone for your valuable input.....hahaha
    Now for another question, when I install the boost and EGT gauges do I need to wire them up to power, as I have no idea how to?
    EGT... Yes, but it is reasonably easy.
    The thermocouple wires will be pre-terminated and go to their respective terminals sama sama power
    If you want dimming the lighting -ve needs to be wired correctly (existing dash light or the dimmer itself) as the Patrol dimmer raises earth
    Boost... IMHO get an analog gauge then all you need is to run the sense tube and then the lighting is sama sama the EGT gauge so can tee off that
  5. #13
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    I did not understand one bit of that ET, but thanks anyway mate scratch-head03-idea-animated-animation-smiley-emoticon-000416-medium.gif
  6. #14
    Buy a boost gauge that has a hollow tube
    Buy an EGT gauge
    Buy a pillar pod
    Buy a Carton
  7. #15
    Perth WA
    61 Post(s)
    Buy an EGT gauge
    Buy a pillar pod
    Buy a Carton
    Bought a Boost gauge
    Bought a EGT gauge
    Bought a Pillar Pod
    Bought a Carton............................................ ....just about finished it, now what?????????
  8. #16
    Buy nother Kart'n
    By nuffa 't'n
    Continue until you forget why you bought a Boost Gauge, EGT gauge and a Pillar Pod
  9. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    AB (29th September 2015), Bigcol (29th September 2015), Woof (29th September 2015)
  10. #17
    Perth WA
    61 Post(s)
    Buy nother Kart'n
    By nuffa 't'n
    I forgot what the question was......................
  11. #18
    ... there was a Question....???
  12. #19
    Perth WA
    61 Post(s)
    Yes there was and I have discovered the answer.............it is 4, am I correct??
  13. The Following 2 Users Say Thank You to Woof For This Useful Post:
    Bigcol (29th September 2015), BigRAWesty (29th September 2015)
  14. #20
    Maybe...
    Depends on how many 2's you have.
    If you only have one 2 then your 1/2 right.
  15. The Following User Says Thank You to the evil twin For This Useful Post:
    Woof (30th September 2015)
