Results 1 to 10 of 13
Thread: Leaky windscreen
    Legendary dom14's Avatar
    38 Post(s)
    Leaky windscreen
    Hey guys,
    The floor of my GQ RB30(both driver and passenger sides) has been getting wet.
    Initially, I had no idea where the water was coming from, but thought from the door
    rubber seals. On close look, I discovered it's actually from the windscreen.
    Leaks are concentrated on lower windscreen corners(from outside).
    Also it's possible the top of the windscreen rubber seal is loose & leaking as well.
    What is the best approach to fix this?
    Should I patch up with some black silicon from outside? or
    Should I pull the whole rubber seal out and clean it and re-apply a lot
    of black windscreen silicon?
    My concern is that since the leak has been there for a while, there might be some rust
    damage to the metal strip of the body where the windscreen fits.
    Only way to find out is to pull the windscreen rubber seal out and clean it.
    Is it an overkill?
    There's a bit of damage to the corners of the floor from leaking water and soil gathered over time.
    But, that easily fixable.
    I'm not sure it's the same thing if the body is rust damaged around the windscreen.
    Any ideas, tips would be great.
    Thanks.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Take to a windscreen place to get them to remove
    it the lower section may be rusty , you could treat it when its out.
    Some fitters cut the seal to make it easier to fit especially the lower corners
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Do you have windscreen cover in your insurance? Some insurance covers you for one free windscreen claim a year. Which is good if, for example, a rock cracks it and then it needs to get replaced and ofcourse getting new rubbers in the process ;-)
    Hello from Under Down Under!
    38 Post(s)
    I did in the past. Currently it's not covered. I reckon I should have "got it done" during the time I had windscreen cover.
    Cheetah Outreach
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    had the same problem, replaced the rubber
    38 Post(s)
    How about I tackle the removal part of the job with this tool?
    I can leave the re-installation part to windscreen guy, if I find it's beyond my league.
    Removing it myself would give me time to clean and fix the edges(any rust damage),
    would it not?
    Cheetah Outreach
  8. #7
    Jan 2015
    19 Post(s)
    it pushes out no glue in it, might need to break the silicone but thats about it, putting it in is a little tricky, need a rope of the right thickness silicone and someone to help
  9. #8
    38 Post(s)
    Quote Originally Posted by garett View Post
    it pushes out no glue in it, might need to break the silicone but that's about it, putting it in is a little tricky, need a rope of the right thickness silicone and someone to help
    Ok, cool. I think I'm gonna go ahead with taking it off, but perhaps leave it to a pro when it gets to putting it back.
    I'll see with some youtubing and with a bit creativity whether I can manage it myself.
    It can be fun, as long as I don't end up smashing the windscreen.
    Thanx mate.
    P.S. I've seen the pro windscreen guys lowering it with a pair of plungers.
    So, I reckon I can use a pair of bathroom plungers?!
    Cheetah Outreach
  10. #9
    Jan 2015
    19 Post(s)
    the glass is not light. wear some gloves and be-careful broken glass is a pain to clean up you think you got it all until you sit down, i had a mate who does windscreens help me do mine and the 2 fixed rears windows when i painted mine. so had all the pro tools and knowledge. need any more details send me a message .
  11. The Following User Says Thank You to garett For This Useful Post:
    dom14 (17th June 2015)
  12. #10
    38 Post(s)
    Cool, thanx mate. I haven't started it yet. I cleaned it today.
    I'm getting into it tomorrow.
    Dom
    Cheetah Outreach
