Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: 4x4 OFFROAD HITCHES
  1. #21
    Ballarat, Vic
    174 Post(s)
    Thats the 'old' McHitch.
    I had one for a while and they are on par with the others of that design and most variations quite good in their own right
    The new style McHitch Auto Couplers are wicked easier.
    I am soooo happy I 'upgraded'
    The ‘auto’ ones do look good ... just watched a video on them. I could be tempted if I ever need a replacement.
    Quite amazing how many different designs there are to do what is basically a pretty simple task.
    A Nomadic Life (Blog)
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    BigRAWesty (27th October 2015)
    Hardcore jack's Avatar
    May 2012
    Ballarat Area
    25 Post(s)
    Just had a look at the McHitch they do look good.
    Only time I had issues hooking up with the Treg was when I was trying to back down a slope, PITA to get the height right. Luckily roofy was there to assist.
    Jack
  5. The Following User Says Thank You to jack For This Useful Post:
    threedogs (29th September 2015)
  6. #23
    W.A. (wandering aust)
    ROFL... yeah, I know what you mean.
    I went the Auto because I travel alone and my Van rig is miles too heavy to "muscle" onto the hitch IE it needs to be all but spot on with the others styles.
    People with lighter rigs or 'helpers' don't have the same issues as it usually means either easy peasy or divorce court...
  7. #24
    Nov 2010
    Getting a life...
    38 Post(s)
    We have the articulated 50mm ball design.. When you have more than one tow vehicle, it's great. And any one can tow it.
    http://www.trailerwarehouse.com.au/c...Body%20(3).JPG
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  8. #25
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Pretty sure I read somewhere that they have a very limited tow ball weight. Like not even 100kg ' s. .
    Quote Originally Posted by biggqwesty View Post
    Bit strange (read useless) but you could be right for some manuf.
    Hyland make different rated versions certainly so they should be OK.
  10. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (27th October 2015), katwoman (27th October 2015)
  11. #27
    When I first started looking at these "off road " hitches, one trailer place said why.
    You're not towing up Billy Goat and a 50mm ball will have all the articulation you will need 4x4ing.
    With the O'Brien I'm happy and only a one man job to hook up. Just a smear of silicon grease every
    now and then and a few pumps of the grease gun, Probable would be better with two tapered bearings
    but works a treat and for $150 very affordable
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #28
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    Quote Originally Posted by Rock Trol View Post
    I have a trig and a treg on camper and trailer. Work really well apart from hitching on un even ground. Then its a pita. I have bought a McHitch adapter for it and I think it will be easier as I can lower the unit on the pin like a toe ball. First outing with it this weekend coming up. I would not bother with the poly blocks now. Get something more modern.
    Tested out on s trip during the long weekend. So easy compared to trig/treg. Was on uneven ground and easily hooked up by my self. Camper was on a slope so car came in at an angle that would have given problems without the mchitch.
    2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
  14. The Following User Says Thank You to Rock Trol For This Useful Post:
    threedogs (27th October 2015)
  15. #29
    Feb 2015
    Got an orac coupling myself & its held up great for more then 10 years! On my next trailer I'm having a d035 fitted. Can't say much for the others.
