Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: New fuel filter wont start
    Advanced
    Oct 2013
    Perth, Western Australia
    CRD 3.0
    Got a ryco fuel filter Z712 and swapped it over from what looked like a filter that had never been removed..
    Anyhow, can't seem to get the fuel up, connected all the hoses, tightend and priming but i can not seem to feel the fuel flowing.. Took off the inlet hose and primed with my thumb on it and fuel comes up after a while, soon as i put it back on the filter and prime more nothing, just air..
    Is there a trick to this?
    Dazz
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    The filter is not sealing for some reason??. Faulty filter or seal? Does it work with the old one on?
    Advanced
    Oct 2013
    Ran out of time, will reconnect it tomorrow
    Advanced
    Nov 2014
    Waikiki, WA
    Quote Originally Posted by p8ence View Post
    CRD 3.0
    Dazz
    Bit confused when you say you removed the inlet hose and you were able to get fuel up?
    You should be removing the outlet hose, it will take many pumps to fill the filter. If you fill new filter before refitting it makes the exercise a lot easier, a lot less pumps.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  6. #5
    Advanced
    Oct 2013
    Quote Originally Posted by Nightjar View Post
    Should have been a bit clearer.. Removed the inlet placed my finger over the hose to block and pumped the bulb and the fuel comes up.. Put it back on and the fuel wont flow
  7. #6
    Since you changed the filter you may have cracked the fuel lines
    thats all I can think of at this stage, re check all fittings
  8. #7
    Aug 2011
    River Heads Q
    4 Post(s)
    Did you fit inlet hose then remove outlet hose from filter only and then pump until fuel comes out?
    Will take a while until filter fills up.
    At the end of the day, all you have is yourself and all you need is your friends (and in our case our Patrol)
    2006 GUI1 4.2TDi Coil Cab "almost" standard
  9. #8
    W.A. (wandering aust)
    Replied to your post on the Club forum, Cobber
  10. #9
    Advanced
    Nov 2014
    Waikiki, WA
    No clearer, have no idea what you are doing?
  11. #10
    Advanced
    Oct 2013
    Sorry Nightjar, thought it was explained as well as I could.
    Finally I got the fuel pumped up but its still not starting.. I think I have air in there cause sometimes when pumping i can hear the air sucking through the fuel..
    Will have to resort in a mech..
    Cheers.
