27th September 2015, 11:35 PM
New fuel filter wont start
CRD 3.0
Got a ryco fuel filter Z712 and swapped it over from what looked like a filter that had never been removed..
Anyhow, can't seem to get the fuel up, connected all the hoses, tightend and priming but i can not seem to feel the fuel flowing.. Took off the inlet hose and primed with my thumb on it and fuel comes up after a while, soon as i put it back on the filter and prime more nothing, just air..
Is there a trick to this?
Dazz
27th September 2015 11:35 PM
28th September 2015, 12:01 AM
The filter is not sealing for some reason??. Faulty filter or seal? Does it work with the old one on?
28th September 2015, 12:36 AM
Ran out of time, will reconnect it tomorrow
28th September 2015, 09:50 AM
p8ence
CRD 3.0
Dazz
Bit confused when you say you removed the inlet hose and you were able to get fuel up?
You should be removing the outlet hose, it will take many pumps to fill the filter. If you fill new filter before refitting it makes the exercise a lot easier, a lot less pumps.
28th September 2015, 11:01 AM
Nightjar
Should have been a bit clearer.. Removed the inlet placed my finger over the hose to block and pumped the bulb and the fuel comes up.. Put it back on and the fuel wont flow
28th September 2015, 11:04 AM
Since you changed the filter you may have cracked the fuel lines
thats all I can think of at this stage, re check all fittings
28th September 2015, 12:31 PM
Did you fit inlet hose then remove outlet hose from filter only and then pump until fuel comes out?
Will take a while until filter fills up.
28th September 2015, 12:37 PM
#8
I am he, fear me
Replied to your post on the Club forum, Cobber
28th September 2015, 07:56 PM
#9
p8ence
No clearer, have no idea what you are doing?
29th September 2015, 11:38 AM
#10
Sorry Nightjar, thought it was explained as well as I could.
Finally I got the fuel pumped up but its still not starting.. I think I have air in there cause sometimes when pumping i can hear the air sucking through the fuel..
Will have to resort in a mech..
Cheers.
