27th September 2015, 10:23 PM
Clutch question
Looking at replacing the clutch, what else should I change while I'm at it?
27th September 2015 10:23 PM
27th September 2015, 11:15 PM
Patrol Guru
Is it a 3.0 litre? If so you will need to change the dual mass flywheel as well to a single or another dual mass.
28th September 2015, 08:05 AM
28th September 2015, 09:17 AM
28th September 2015, 09:54 AM
Patrol Guru
threedogs
Rear main seal
Good idea.
29th September 2015, 08:14 PM
Rock Trol
Did you mean RB30 Patrol?! AFAIK, 3.0 litre RB30 is not a DMF.
26th October 2015, 10:13 PM
Remember to change the fluid! I've seen people who haven't bothered to bleed the slave cylinder and change the fluid while they're at it
16th December 2015, 05:01 PM
#8
threedogs
Rear main seal
THIS!
Small thing, but can save you from having to pull the entire gearbox out later down the track.
24th December 2015, 05:12 PM
#9
I had done clutch replacement recently, and it had small oil leak from gearbox bell housing and from transfer gearbox rear propeller shaft end. these were the things replaced,
*engine crankshaft oil seal rear
*clutch plate
*pressure plate
*release bearing
*bearing fork
*fork ball pin
*fork boot (dust cover)
*gearbox input shaft oil seal
*transfer box rear end oil seal
Apply small amount of grease where metal slides or turn. It would be great if you repack clutch release bearing with good grease.
