Results 1 to 8 of 8
Thread: Qeustion about stall in low range downhill
    Dec 2014
    Hi all,
    Just had a training day with the 4wd central coast club and noticed on two occasions going down steep hills the 4.5l Patrol would stall as I leveled off after a steep descent. It behaved as if if were a manual stopped in gears. Read somewhere that "the gu does not fully lock the clutch in the converter when in low range 1st". Would that be the source of the problem ? Or is there a different problem I might be facing? Note that I have recently changed the transmission oil & filter.
    Any advice highly appreciated.
    Cheers,
    S.
    is it a dual fuel 4.5 auto, if so what fuel were you using
    W.A. (wandering aust)
    What he said ^^^^
    Will more likely be a fuel issue than the tranny
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Unless i am mistaken, the gu (gq as well maybe idk) auto won't lock up in first full stop.
    Possibly try a hill in 2nd low and see what happens.
    Could be fuel related also. I haven't ever stalled my auto.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. #5
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Pretty sure the auto in most Cars doesn't lock in 1st or 2nd regardless of range unless fitted with some sorta converter lock up overide.
    So unless you've got something fitted that your unaware of??
    Im thinking its more a float level issue,
  8. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Im thinking its more a float level issue, what country are you in too please?
    4.5 litre are efi?
    tappin from tassie
    Hello from Under Down Under!
  9. #8
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    If when the motor stalls and the car comes to shuddering stop, your trans has big problems. If when the motor stalls and the car rolls to a stop, I'm betting you have LPG and it just needs a good tune.
Tags for this Thread
