Know the feeling only too well just couldnt quite make it but you get that on the big jobs.
@ Cuppa Mick replied to my email and does not have any stock sizes all are custom,
So I gave him 1200 x 500 x 200 mm as a basic size I think this works out at 120 ltr
could be wrong,
I really need to get under the camper and measure inbetween the ribs.
Might change it to 1000mm x 500mm x 200mm we'll see
Well I received my quote for a 120 litre fresh water tank 120cm x 50cm x20cm,
No doubt they make a quality item but at $290 plus freight I think I'll pass.
I can buy a black plastic caravan style tank that holds 82 ltres with a full skid plate mount
kit for $180.
If I was using it a bit more maybe I could be tempted, but I seem to be
using my camper less and less lately
Just as well you didn’t get a quote from Atlas Tanks TD! When I had my tank made by Award (880 x 760 x 250 - 160 litres with breathers, two inlets & two outlets - one a 40mm opening with an ‘o’ ring sealed screw top for filling with a jerry or funnel) cost was $320 + $70 freight in 2012. Quotes from Atlas (& a few others) for exactly the same design were all around double that at around the $900 mark.
The black plastic one will do the job if well supported & protected from flying rocks though. If it does get damaged/spring a leak - forget trying to repair it - just replace. I’d use one again if it fitted the space I wanted to put it in.
For the future reference for others the Award Tanks have a double skin top (can withstand being knelt on) & have internal baffles to reduce unwanted weight shifting of their contents. They are made of thick HDPE which is readily heat welded should a repair ever be required. They also make a few ‘standard’ sizes which are a little cheaper.
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
@ Cuppa this is the one I'll probably end up getting, pretty well protected'
At 82kg plus the cover that will give me abit more ballast to balance out the trailer'
Damn just remembered I was selling my 55lt Dolium tank, fits across the front of a 6x4 trailer
or across the back of a tub, its the grey tank in my 2010 Hilux Tub
