Results 1 to 8 of 8
Thread: Electric Windows working for set time after key removed
    Sep 2014
    Fraser Island
    Smile Electric Windows working for set time after key removed
    Hi All
    Just looking for some help to see if I can get the electric windows in patrol working for say 2 minutes after the key has been removed from the ignition , Like every other car I have owned does .
    thanks in advance
  2. The Following User Says Thank You to HappyCamper* For This Useful Post:
    Stevelb21 (27th September 2015)
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Have you tried? My Patrol does this
    Steve
    2011 Patrol Safari 4.8 (Fitek)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    they usually only work until drivers door is opened
    atleast the ones I have had - didnt know there was a time limit.............
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    It annoyed me so much that I fitted a switch on the dash to power them rather than have to put the key back in..
    John
    Hardcore
    central coast nsw
    Was going to fix mine to do exactly that as its a pita having to put keys back in.
    I already have a timer that allows me to use the stereo, so I can use it and rev cameras with ign off.
    I was thinking about hooking up a suitable relay to timers output and running to window control box.
    The timer is variable & can be activated by a simple push button on/off also.
    see Jaycar for kit. You could do a search ebay for a suitable unit.
    cheers
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
    Aug 2010
    adelaide
    have a read of this old thread and yendor has a good write up in it
    http://www.nissanpatrol.com.au/forum...dows-Mod/page2
    OH LEATHER IS NICE
    Expert mjr350's Avatar
    Sep 2014
    Port Macquarie
    I've been thinking about this for a while. My old VY commodore had the option of accessories off with either key off or door opened so I got used to everything still powered until I opened the door.
    Jaycar do a timer kit that will hold the ignition on for a set time but I really like the idea of the opened door.
    Im going to see if i can program an Arduino board to simply stay powered once on until it senses the interior light.
  10. #8
    Sep 2014
    Port Macquarie
    Ive got it.
    2 SPDT relays is all you need to keep the accessories on until you open a door.
    So easy to build so I gave it a go and it tests fine so should work well. Latches closed when the ignition is turnedon and doesn't open until its earthed out (opening door)
