19th September 2015, 07:00 AM
MY 2002 Gu 111 has the engine light flashing and the subtank light on?
Hi can someone help a damsel in distress with ideas and information on what is causing this problem? so far I have put an new earth cable from battery to chassis by RHS headlight, and have taken both leads off the battery overnight. Kind regards Di
Oh I forgot to say I have a 2002 4.2 diesel
19th September 2015 07:00 AM
19th September 2015, 08:06 AM
Welcome to the forum mate. Someone will be along that may help
19th September 2015, 08:09 AM
Check your alternator sounds silly but when my one went on my patrol I had those dashboard lights on worth a look
19th September 2015, 10:01 PM
Advanced
Welcome - might need to post this question in the mechanical section, but with an engine light id suggest you need to either get it into Nissan so that can plug it into their Consult 2 Tool to run diagnostics, or find a mechanic whom has a diagnostic tool to fit the 14pin diagnostic socket in the 4.2 as it is different from the later 3.0 models. If you post this in the mechanical section on this forum im sure you will get some more accurate advice.
Cheers,
Jack
Current - 2011 GUVII 3.0 CRD
Previous - 2004 GUIV 3.0DI "The Grenade" Literally ...
100 LC V8, 150 D4 Prado, 200 Series V8D .... and a Discovery D2V8 in between ... what was i thinking?
20th September 2015, 08:46 AM
Travelling Podologist
Big boy87
This sounds likely. Could be time for new alternator brushes.
A Nomadic Life (Blog)
20th September 2015, 12:07 PM
maybe a split fuel line or dirty filter as well . easy to check
Welcome to the forum too enjoy
20th September 2015, 05:17 PM
welcome to the forum Happy.
23rd September 2015, 06:57 PM
Dribble Master
G'day to you and welcome aboard mate
23rd September 2015, 07:00 PM
Welcome aboard mate. .......
23rd September 2015, 07:45 PM
Legendary
Welcome to the forum mate. My GU did that when the alternator failed. Worthe a look.
