Results 1 to 10 of 18
Thread: Gu patrol 4.5
    Sep 2015
    Donnybrook
    Gu patrol 4.5
    Wondering anyone had experience with upgrading the cams with these motor and where would I look for a shift kit to suit the auto any help or direction would be appreciated cheers
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    12 Post(s)
    TransGo shift kit can usually be found on Ebay for around $140. Other option is Nomad valve body for close to $1200..
    Not too difficult to drop the valve body and do yourself if you're familiar with this kind of thing.
    Don't bother if the box has 200 + kms..
    A lot of work to change a camshaft for limited returns and you wouldn't get much benefit without an engine management system. You can't modify the TB45 ECU.
    TB45 engines respond well to forced induction.
    John
    Sep 2015
    Donnybrook
    Cheers for the info might have to look at forced induction bloody spewin just fair few bob putting another motor into it sounding like a should of done a 5.7 conversion
    bolt a turbo to it with some head work and extractors
    could see you pulling 250rwkw easily
    Sep 2015
    Donnybrook
    What will be the difference between a transgo shift kit to the nomad valve body apart from the price
    Sep 2015
    Donnybrook
    Bloody hell 6.5k for a turbo kit and would I need a piggyback ecu
    Morayfield, QLD
    12 Post(s)
    Quote Originally Posted by Big boy87 View Post
    If you're serious about wanting to turbo it, have a look at my turbo install thread in the DIY section. I changed my mind and went to diesel so now all my turbo gear is for sale including the Xede piggyback.
    I used the manifold and the cheap Ebay intercooler on my TD42.
    Here's an overall pic of most of the stuff..
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
    Big boy87 (17th September 2015)
  10. #8
    Morayfield, QLD
    12 Post(s)
    I have used both. I installed my own TransGo kit and used it for a few years. I still have the valve body here with it fitted.
    I now have a Nomad because I got it very very cheaply from a damaged trans.
    I was expecting the Nomad to be a lot crisper but honestly there's not a big difference between the 2.
    John
  11. The Following User Says Thank You to jff45 For This Useful Post:
  12. #9
    Sep 2015
    Donnybrook
    What would that be worth caught between a rock and a hard place deciding whether to look round for diesel but open to all ideas
  13. #10
    Morayfield, QLD
    12 Post(s)
    $1000
    Converting to diesel is not cheap especially if you want to go to factory turbo and keep the auto.
    Mine has cost me $10k but that was my initial budget anyway and I did everything myself.
    John
