Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: High Idle with Headlights On
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Howdy
    Another quick one hopefully - whenever I turn the headlights on (normal beam) the engine idles up about 250-300 rpm. If I pull up to a set of lights as an example, I can feel it lurching - drop it into neutral and it heads straight up to 900 plus rpm - turn the headlights off and sure enough, every time it just lowers immediately back to 650 rpm.
    Understand that accessories use power and in turn they can cause it to idle up a little, but this has only started a month or so ago, and is a huge rpm jump.
    Thoughts and opinions??
    Thanks in advance as always!!!!
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    does it still idle up when you turn the air con on?
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Maybe your running a bit to much wattage or the alternator might be fatigued
    Oct 2010
    Thanks lads - air con kicks it up about 50-75 rpm at full tilt (on high) with lights off. Alternator is only 5 months old and was a new 110 amp Hitachi (bigger than stock unit). Not sure what you mean by running too much wattage mate?? Have Narva driving lights and they were put in about the same time as the alternator.
  6. #5
    TRAFALGAR VIC
    35 Post(s)
    Thuoght the globes might have been drawing more power than the alternator could keep up with
  7. #6
    Sep 2010
    on the coast W.A.
    MMMM, the draw from the lights is sending a message somewhere, and this is causing another message to go to the hi idle unit me thinks.
  8. #7
    Oct 2010
    Quote Originally Posted by the ferret View Post
    All very confusing to me mate!! lol
    Just becoming somewhat of an issue - the lurching at lights is reasonably prominent due to the engine wanting to take off being idled up - if I let the foot off the brake in idle, I'd easily climb a hill without touching the accelerator!!! Hmmmm, is that a good thing? I think not!!
  9. #8
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Bigrig View Post
    Howdy
    Maaate See the lil pedal on the right...... take ur foot off it haahhahahahahahahahahahahah (Vino Night)
  10. #9
    Sep 2010
    on the coast W.A.
    I spose it wouldn't hurt to check all your earths, a bad earth can some times cause all sorts of magical events, mine was a bad earth and when I turned the headlights on, the horn would blow, work that one out!!
  11. #10
    TRAFALGAR VIC
    35 Post(s)
    Just out of curiosity disconnect a set of driving lights and see what happens
    if the revs drop theres a starting point
