12th September 2015, 08:01 PM
#11
There a 4 bolt holes, I've taken another pic hopefully this shows the layout better
93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
12th September 2015 08:01 PM
12th September 2015, 08:47 PM
#12
Dribble Master
well in that case it does look like your good to go
The Following User Says Thank You to Clunk For This Useful Post:
Patrol'n (12th September 2015)
12th September 2015, 09:02 PM
#13
Then hi ho, hi ho, winch shopping I shall go!
Good good, thanks blokes 😀
12th September 2015, 09:11 PM
#14
Patrol'n
Geeze that's a light weight construction..
I'd be going a cradle to be sure.
12th September 2015, 09:12 PM
#15
Fair comment mate, any ideas on where to get a cradle?
12th September 2015, 09:24 PM
#16
Dribble Master
biggqwesty
really, so what thickness should it be?
12th September 2015, 09:26 PM
#17
Clunk
Not so much thickness but there isn't much structure behind it.
Most winch bars have a bit for angle steel either vertical or horizontal which the winch mounts to. It spreads the load much nicer across the bar.
A shoit load better than a bit of 3mm plate anyway
13th September 2015, 12:51 PM
#18
biggqwesty
So would something like this welded into the bar be ok?
http://www.ebay.com.au/itm/Steel-Uni...item28014a143f
13th September 2015, 12:54 PM
#19
That's a cradle so yes something like that to bolt to chassis and then fairlead on the bar..
Just make sure the cradles compatability as to me that one you linked won't fit without extensive mods.
Sent from my SM-G800Y using Tapatalk
The Following User Says Thank You to BigRAWesty For This Useful Post:
Patrol'n (13th September 2015)
13th September 2015, 02:41 PM
#20
Ideally wouldnt you have your winch bolted to a cradle that is seperate to the bull bar, like a capsule
then fit the bullbar over that.
@ Clunk it does look a tad light, maybe some 6mm plate over those
4 bolts with grade 8 bolts and HT washers, to bolt the winch in place.?
You will need a low mount about 9.5 ,The Runva is well priced IMO
The Following User Says Thank You to threedogs For This Useful Post:
