29th June 2019, 03:00 PM
ZD30 engine can I crack injector nut ?
Engine died and wont restart. Removed intercooler. I can now see the nut that connects injector pipe to injector.
Question. can i njust undo the nut so i can tell if fuel is being pumped, or do I need to dismantel things further so i can also put a spanner onto whatever that nut is screwing onto.
Im worried if i just put a spanner on the nut and try to loosen it, I will twist/damage whatever is inside the rocker cover
29th June 2019 03:00 PM
29th June 2019, 04:13 PM
Patrol Guru
Nah. Just crack it mate. Shouldn't be an issue. As long as you're talking about the nut holding the line to the injector.
The Following User Says Thank You to 0-TJ-0 For This Useful Post:
29th June 2019, 04:15 PM
Dickhead, used my brains and cracked the nut other end of the line, on the pump. Undid it 3 or 4 flats, reached inside with the door open so i could watch and hit the starter,,,,,,,, not even a drop,,,,,Hmmm.
29th June 2019, 04:18 PM
That was me i was calling a dickhead.
The Following User Says Thank You to Dagwill For This Useful Post:
30th June 2019, 11:10 AM
Patrol Guru
