Results 1 to 10 of 17
Thread: GQ dashpod
    Advanced SharkyGQ's Avatar
    Aug 2015
    Central Highlands Vic
    GQ dashpod
    Knocked this up other day a dashpod. Houses my 2 x radios and has 3 x 12v outlets.
    Steve
    _____________
    92 GQ TI
  2. The Following 4 Users Say Thank You to SharkyGQ For This Useful Post:
    Bigcol (30th August 2015), Clunk (31st August 2015), mudnut (31st August 2015), Victory (31st August 2015)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    that looks really nice mate
    Aug 2015
    Thanks Col wasn't entirely happy with it but came up ok.
    Steve
    _____________
    92 GQ TI
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Like it mate. Had a go at one and wasn't happy, so binned it.
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    its not that much different to the ones you can buy from Consoles.com.au
    but it would have been a hell of a lot cheaper
    thats for sure
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I like the old Pierce Simpson CB.........
    often think about fitting it, but not sure if it would get used or be a waste of time
    Aug 2015
    Thanks guys I had most of the bits just had to buy carpet.
    Steve
    _____________
    92 GQ TI
  10. #8
    43 Post(s)
    How have you run wires into dash and how have you secured it? I'm torn between overhead or dash console.
    I'm tall to head safety is my no.1 issue with over head.
    But securing and wires is my concern with dash mount.
    Sent from my SM-G800Y using Tapatalk
    Mate, I've got an overhead console, the one that runs along the top of the window, not the centre. Never even come close to bashing me head
  12. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (31st August 2015)
  13. #10
    Aug 2015
    Hi Westy I ran wires/cables out the back of pod, it then runs along the bottom of the windscreen. I didn't want to drill big holes in top of dash. I had a GQ years back with a prof built dashpod (Department of interiors from memory)and I remembered it had a flat thin bit of sort of like tin at the front which slid under the dashtop and between radio facia (Hope that makes sense. and the rear of it utilises the main dash bolts near the demister vent. I copied the front design but I remember what a cow of a job it was mucking around with factory dash bolts theyre very close to windscreen making it hard accessing so I used L brackets instead at the rear/side and screwed into metal part of dash so good and secure. tHe wires are only seen where it comes out of rear to windscreen so not far and from there reasonably well hidden. I had a dashpod like this one in pic in my old patrol and used its mounting design
    Steve
    _____________
    92 GQ TI
  14. The Following 2 Users Say Thank You to SharkyGQ For This Useful Post:
    BigRAWesty (31st August 2015), Clunk (31st August 2015)
