Results 11 to 20 of 21
Thread: Rear storage unit
    43 Post(s)
    Bugger. Although I see you still have the carpet fitted. Remove that and there's your fit.
    Seeing I have kids when the seats are in access is nil. So I've placed a 75L custom stainless water tank in that gap. Hose comes out the side. Was going to place a pump and out let in the rear for it but now we have the van it'll be staying staying a gravity feed
    Sent from my SM-G800Y using Tapatalk
    Advanced SharkyGQ's Avatar
    Aug 2015
    Central Highlands Vic
    There is no carpet on the inside so between inside of box and wheel arch mount. Basically I only carpeted bits that are seen with exception of behind second row seats. Or were you referring to the floor carpet?. Where is your water tank? Another pic with carpet on.
    Steve
    _____________
    92 GQ TI
  4. The Following 2 Users Say Thank You to SharkyGQ For This Useful Post:
    BigRAWesty (1st September 2015), rusty_nail (2nd September 2015)
  5. #13
    43 Post(s)
    Sorry I thought I saw the stock carpet over the arches.
    Not sure if i have a pic.of the tank or not.
    I'll take some tomorrow
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    top job mate. thanks for sharing
  7. #15
    Aug 2015
    Oh that carpet yeah that's still there mate, sorry wasn't sure which ya meant, Probably could get enough clearance doing that. Thanks Blocko cheers mate
    Steve
    _____________
    92 GQ TI
  8. The Following User Says Thank You to SharkyGQ For This Useful Post:
    BigRAWesty (2nd September 2015)
  9. #16
    Aug 2015
    Done some more on it. Started to do the centre bit now. Has fridge slide, 3rd battery in behind fridge, draw on left and slide out table above draw. Also has a cavity beside draw can throw heaps in too.
    Steve
    _____________
    92 GQ TI
  10. The Following 2 Users Say Thank You to SharkyGQ For This Useful Post:
    Bigcol (20th September 2015), Clunk (21st September 2015)
  11. #17
    Apr 2015
    Hobart TAS
    top job mate. What are you going to use for tie down points for the fridge.
  12. #18
    Aug 2015
    Thanks mate my waeco is a pov pack one and doesn't have handles/tie downs. I will be making a roof for it that will be removable when not using fridge. This will encase it in there and wont go anywhere. I've had to do this everytime I've made a storage unit
    Steve
    _____________
    92 GQ TI
  13. The Following User Says Thank You to SharkyGQ For This Useful Post:
    blocko05 (25th September 2015)
  14. #19
    May 2015
    Great job mate!!!
  15. #20
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Great work mate. Very nice design. Might look at something very similar down the road if I decide on fridge and draw system.
    Hope it functions as well as it looks
