Started last week making up my rear storage, drawer, fridge unit. Made some more progress on it today
Steve
_____________
92 GQ TI
4bye4 (30th August 2015), ashmccormick (31st August 2015), Automatia (19th December 2015), Clunk (31st August 2015), lucus30 (30th August 2015)
looking good mate
Looks good. My talent with wood extends to lighting fires and throwing it for the dog to fetch.
Bigcol (30th August 2015), BigRAWesty (31st August 2015), Clunk (31st August 2015)
Thanks Guys, hopefully be good when finished
Steve
_____________
92 GQ TI
Great work mate! Look forward to seeing this progress as I'm currently drawing up a plan for some rear storage!
GQ Patrol, TD42 NA, 33's, Snorkel, 2" inch lift, Dual Batteries, Roof Rack, Awning... Many more to come
Great start Sharky. Any idea what's going to fill the front spots? And are the wheel arches still accessible?
Sent from my SM-G800Y using Tapatalk
Very nice work, envious of your wood working skills
Thanks everyone, Westy the wheel arches are accessable via lift up wings. However the very front at around where the second row seat is screwed on. I have a fusebox on one side that wiring will be going into and was thinking of putting my either my invertor or the fridge mobitronic (240v to 12v reducer) in other side. Was all good as if blew a fuse etc 4 screws out to fix but problem I now have which I didn't think of is I'm building or more the fact modifying a cargo barrier to sit on top and this will pin down any easy way of changing fuses etc. So might have to mod that bit so I don't have to remove barrier to do a fuse. Will try and get under pics if you like mate
Steve
_____________
92 GQ TI
All good. If you do split the barrier run 2 bits of flat from the outside bolts back to the rear seat belt bolts in the wheel arches.
Have a look at my draws build for the pics
Thanks mate just had a look at your mounting and nice work there. Only thing is I cant fit strap in between as it will push side boxes out and tolerance fit with one across now. I'm thinking the tops on mine although cant see in pics are 2 piece not 1 like pic of uncovered one, I'm thinking that the shorter front section making it 2 pieces so can remove even if barrier is in place, thus giving access to those areas.
Steve
_____________
92 GQ TI
BigRAWesty (1st September 2015)
