Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Catchcan hose
    Advanced
    Jul 2015
    ORANGE NSW
    Catchcan hose
    HI everyone just got a new provent catch can but nothing else came with it now the pipe coming from the tappet cover dose it go to the top or bottom of the provent can any help please,
    Go grab a heater hose off an XA falcon they are flared each end.
  4. The Following User Says Thank You to threedogs For This Useful Post:
    ova50 (25th August 2015)
  5. #3
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Was a CRD
  6. #4
    I dont use a pro-vent but does it have arrows on it at all,
    I would guess it goes to the top and the bottom goes to the air intake.
  7. #5
    175 Post(s)
    I have gone this way on my 3L and do not recommend it.
    After about a year of this hose being fitted it literally began sweating oil through the hose wall and dripping out all over the block. What is worse, hose is deteriorating away from the inside and bits of rubber got caught in the catch can filter. I have been told this is not a oil compatible hose form the beginning but took a punt anyway and yeah the end result is a ruined hose and bit of panic when it began leaking all over the driveway.
    Yes it is a nice factory looking fit, but it is not the right hose.
  8. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    growler2058 (25th August 2015), MudRunnerTD (29th August 2015), ova50 (25th August 2015)
  9. #6
    Nov 2011
    Seems to be a problem with the link.
    In eBay look for: 25mm - 16mm (1.00" - 0.63") Straight Silicone Reducer Hose Black AeroFlow
    Was a CRD
  10. #7
    175 Post(s)
    Here is the falcon hose. See a very neat finish and fit. But shame it's just not the right one.
    175 Post(s)
    Here is my catch an with the ugly reducers.
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #9
    Advanced
    Jul 2015
    ORANGE NSW
    thanks everyone moonie
  14. #10
    The master farter
    mudski's Avatar
    462 Post(s)
    The inlet is at the top and out the bottom. Don't forget to put a hose on the drain port and block it or put a tap in it....
    As for reducers I used 1inch OD to 5/8OD copper reducers from Reeces. The 5/8 was good for the outlet to the intake pipe as its bigger than the hose from the motor, about 1/2. So for the intake fitting I just cut a 2inch piece of 1/2OD copper pipe, flared one end with a ball pien hammer as I dont have a flaring tool, then this slid inside the 5/8 end and I just glued it in with some plumber glue. Never moved...
