Results 11 to 20 of 31
Thread: Crimping tool
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    I have one of the Jaycar crimpers. Its not bad but I found that it tends squash two of the opposing sides where the jaws meet.
    When I done my dual battery I use a Anderson Plug crimper for the main battery wires. (pic)
    Was a CRD
    Won't they be the same though?
    Nah, the dies start at 4mm2 and step up in 2mm increments till the heavy gauges.
    The kits with quality dies can cost but the Chinee Cheapies around $60 are quite adequate for hobby use (I have one same as cuppas link as my loaner kit)
  4. #13
    Expert ashmccormick's Avatar
    Jul 2015
    North Brisbane
    Best option is to measure up cable sizes and get an auto sparky to crimp them.
    I live in the sticks so I had to improvise a little... Hydraulic bottle jack under the tie down points, soldered them and then shrink wrapped. Worked a treat for me
  5. The Following User Says Thank You to ashmccormick For This Useful Post:
    blocko05 (21st August 2015)
  6. #14
    Legendary happygu's Avatar
    I always crimp and solder the battery lugs in my truck.....
    This helps to ensure a good connection over time, escpecially if you dont quite have the correct crimper
  7. #15
    I have the same kit as Cuppa and it's awesome. Comes with 6sets or dies all different sizes up to 90mm2
    Note that some of the guys are posting pics of the crimpers for Anderson plugs which are completely different and I have them too. They do the job different.
  8. #16
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I also used the Ebay hydraulic crimper for my winch install. I added pics of crimper and result in the thread I did here.
    Like Cuppa, I had to go one size under for the correct crimp. For the 50mm2 cable I had to go once with the 50mm dies then pass the 35mm over it.
    The reason I did this is because I soldered the exposed copper near the end of the lug and found it wicked through the crimp. This is a sign that the crimp is not "gas tight" as it should be. Didn't happen after using the 35mm dies.
    I just assumed the chinese dies weren't precise enough.
    This is the crimper and the result on 50mm2 cable after passing the 35mm dies.
    John
  9. #17
    I do a double length crimp with mine rather than a single central crimp like that, I crimp the full length of the lug.
  10. #18
    And these shears make everything possible
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    jff45 (21st August 2015), Robo (24th August 2015)
  12. #19
    Morayfield, QLD
    Your dies are thinner. That looks neat. Wouldn't look as neat with the thicker dies I think.
    I like those shears.
    John
  13. #20
    A grinder works well too for cutting big cables neatly =]
