Results 1 to 7 of 7
Thread: TB48 Question I can't find the answer to....
    Expert alterastro's Avatar
    Jul 2012
    Up Over - UK
    Ok so possibly a silly question, but I've searched and can't find an answer...
    Is the TB48 timing belt or chain? If belt, what is the replacement schedule for it and if chain, should it be replaced after x miles or years?
    Thanking you!
    Nick
    Here's some info I find when doing a quick search
    TB48are chain
    ZD30 are gear & chain
    TD42are gear
    RD28 are belt
    TB42 & 45 are chain
    Belts are the only drive method that has a scheduled replacement interval
  4. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    alterastro (19th August 2015), Winnie (19th August 2015)
    Jul 2012
    Up Over - UK
    Lol I've been searching all morning and couldn't find a definitive answer! Thanks.
    So if there is no scheduled replacement interval, does that mean it lasts a lifetime? It's only done 80,000 km but 12 years old...
    Patrol Guru cgm's Avatar
    Jul 2012
    Ballarat
    TB48 is definitely chain and meant to last the distance (obviously as much as reat of the engine). I think in most cases that should be true. I had one in Saudi though that was giving me a small noise at low revs. Turned out to be the tensioner on the timing chain. But I'm betting now someone before me hadn't serviced it properly. I sold it to a mate when I left and it died in the bottom end. Only about 200k on the odometer. His old GQ had over 500k without issues in the same conditions. The heat is tough on them.
    Thanks, Cameron
    No Patrol now - Just good memories!
  7. The Following User Says Thank You to cgm For This Useful Post:
  8. #5
    Jul 2012
    Ballarat
    With 80k on the clock and chain rather than belt, you have no issues at all.
    Thanks, Cameron
  9. The Following User Says Thank You to cgm For This Useful Post:
  10. #6
    Aug 2015
    Yeah, definately chain... There is no aftermarket option that I have been able to find so, the genuine must be tough as nails!
  11. #7
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    Yep chain, the prev owner of mine had a blind monkey do the timing work and there were burnt out valves etc as a result. The chain however after 150k was in tip top shape.
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
