19th August 2015, 11:25 PM
Any photos of the new Nissan unit?
19th August 2015 11:25 PM
20th August 2015, 03:07 PM
Bacho86
I thought TJM / Airtec made the Nissan ones... could be wrong?
Think you are right on that mate.
Apparently the Nissan snorkels can leak where the Nissan badge is located, never happened to me but seen a few threads about it.
http://www.partsweb.net.au/default/c...363/image/441/
24th August 2015, 11:33 PM
Gone the Nissan unit and fitting myself now.
It all came down to cost and I like the look of the genuine one.
Will keep an eye out for any issues.
15th February 2017, 06:10 PM
Hi! i have a nissan snorkel, problem is i dont have the installation template. Do you guys have a spare? cheers
1st March 2017, 11:38 AM
flyfin
I'll have a look at home but think I threw it out. Sorry only just seen this question.
The Following User Says Thank You to rusty00 For This Useful Post:
threedogs (1st March 2017)
1st March 2017, 12:05 PM
I wonder if its worth checking the sealant after so mant years
I think mine is 3 years old, might see if it can be checked
via the warranty,lol
3rd March 2017, 01:49 PM
#17
flyfin
Sorry I can't find it, must have thrown it out.
7th September 2017, 09:29 PM
#18
Mine has a genuine Nissan snorkel , when I 1st bought it 2 yrs ago ( it's a 2002 model ) I did the plastic bag check & it continued to run & I could hear the air sucking in inside the guard so off with the wheel , inner guard etc ' check it out . From memory where ever there are joins the plastic sort of fits inside the other piece with a foam rubber type seal between - pretty ordinary set up really , I'm going to make 1 out of stainless pipe with all the external bends welded on but internally the bends will be silicon hose clamped onto the stainless . That's the plan anyway . Mainly because I know it'll be right - the current setup is a constant worry whether or not the urethane is still sealing properly etc . 1 of the main problem points I found is where the plastic pipe comes through into the air box
