Results 1 to 10 of 19
Thread: PEDAL throttle position sensor issue zd30
    Expert Limmy's Avatar
    hi guys
    2005 gu4 zd30
    I think i got the problem of faulty TPS . Once in a while the pedal would be non-responsive ( not revving ) . a few seconds later it works. I'm going to try and take it out and drill and clean as recommended on the forum. If all fails
    Could i replace with one like this http://www.ebay.com.au/itm/GENUINE-N...item1c4352a573
    Do i need to do any adjusments or reset when i take out the tps and put it back ? or straight fit in ?
    Let me know any other recommendations regarding removal, cleaning etc..
    thanks heaps
    Limmy
    175 Post(s)
    Hey mate.
    Nissan recalled the pedals/TPS on some VIN ranges. Yours is out of date range, but I know for a fact some 2005 are affected, as my workmates early 2005 was done free of charge by nissan. Might pay to get in touch with Nissan and find out ?
    https://www.recalls.gov.au/content/i...itemId/1051841
    Limmy (15th August 2015)
    unfortunately i just missed out with my vin
    I heard some of the Members from OS remove the TPS and drill {carefully]
    a small hole in it and squirt with CRC or similar with good results, di for new learningsconnect the battery
    while you do this as well, resets the ECU
    Give Mudski a PM he may stock TPS's
  8. #5
    i might try and crack it open.
    If i get a new unit. Do i need to adjust ? or straight replacement ?
  9. #6
    462 Post(s)
    Just remove and refit.
    Limmy (16th August 2015)
  11. #7
    hi guys
    i bought a brand new replacement and changed it over. still same problems. $(KGrHqFHJEgE92!f41LtBPh(6LSldw--60_12.JPG
    I also noticed there a little BOSCH sensor on the bottom of the pedal ? what does that do ?
    any other ideas ?
  12. #8
    How's the serenity boots's Avatar
    Sep 2011
    Is it overboosting ? hitting limp mode ?
  13. #9
    Quote Originally Posted by boots View Post
    when im in gear and press the pedal down nothing happens. then i try step on a few more times. then it works normally
    i think its to do with pedal
    im out of ideas now
  14. #10
    Sep 2011
    You have not answered the question. What is your boost pressure ? Your symptoms could be related to something else.
