Results 1 to 3 of 3
Thread: SOLD. Air bags x 4 (will separate) Brand new with top mounting brackets - No Longer Available
    Ballarat, Vic
    174 Post(s)
    4 x DeNominator2 Airbags. (Will separate into pairs).
    11.5inch (30cms) fully extended, 2.8inch (7cms) collapsed. 7.25inch (18.4cms) diameter
    ? inch port. Rated to 600psi & weight capacity of up to 3049 lbs (1.3 tonnes) per bag.
    Imported from USA.
    http://www.airbagit.com/Air-Springs-Air-Bag?/baga-26aaaa.htm
    Top quality.
    With top mounting brackets. (can be altered to suit your vehicle if necessary)
    Bought to fit to a Nissan Civilian (motorhome) but never fitted prior to selling it. Will suit other leaf sprung vehicles. Measure clearance between top of leaf springs & chassis (remove bump stop), plus ensure sufficient clearance around them to ensure they dont rub, to see if they will fit (or may be fitted using a separate bottom mounting plate to one side of springs - depends on vehicle. (Lots of helpful info on the Airbagit web site)
    Air lines & fittings readily available at places like EnZed.
    Will separate into pairs - $120 per pair or $200 for all four. Collect from Ballarat. Advertised elsewhere.
    List Date: 8/10/2015
    For more info, click here to view the original listing: SOLD. Air bags x 4 (will separate) Brand new with top mounting brackets
    This item is no longer available.
    Ballarat, Vic
    174 Post(s)
    .................Sold............................. .....
    A Nomadic Life (Blog)
    581 Post(s)
    Thread closed.
