Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Securing a fridge without drawers
    Oct 2011
    melbourne
    As the title suggests. How do best secure your fridge in the rear of a gu wagon without drawers?
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    If you have a cargo barrier you can secure a strap there and then use one of the loops at the rear (one on either side) for the front. That will hold it down.
    2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
    Quote Originally Posted by Rock Trol View Post
    That's exactly what I used to do before I got my drawers
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    I use the child anchor restraint points on the LH side of the boot floor - one at the front and one in the rear (when the kids aren't using them). Worked a treat last trip too - just gotta work out a better way to secure all the other stuff to stop crashing into the fridge!
  6. #5
    You could cut a piece of ply to cover the
    floor in the cargo area, then screw an Engel Transit base to that.
    One finger operation and no straps. I've used this system
    for over 20 yrs in two different 4x4s
    http://www.ebay.com.au/itm/Genuine-E...item3a7eeb1989
  7. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (9th August 2015)
  8. #6
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    I my GQ i used to loop a small press buckle strap thing thru the eyelet where the seat belt mounts to the floor then around the fridge and thru the handles... Yes dodgy but it never moved. Yet to load the fridge into the GU.. But i'll try and find a neater solution when time comes....
    2003 GU SIII Auto Grenade. All the goodies.
  9. #7
    175 Post(s)
    I use those tie down straps with the eyelets it came with, and one of the eyelets is bolted down to one of the bolts that used to hold the rear seats, and the another strap around the other side of the fridge and onto the cargo barrier. Never moved at all ...
    Hard to explain and I don't have a photo of exactly what I mean hope it made sense.
    http://www.ebay.com.au/itm/NEW-UNIMA...item20d40857e2
    a bit left field, but would still work lol [bored]
  11. #9
    Oct 2011
    melbourne
    Thanks guys. No cargo barrier so I'll have a play around and see what works best
  12. #10
    Mar 2013
    NE Melbourne
    Isn't there 4 tie down points in each corner of the load area? Or is the fridge covering one up?
    You could thread a turnbuckle strap through the rear seat (between top and bottom cushions) and secure to the seat frame.
