Results 1 to 5 of 5
Thread: Has Nissan installed the winch correctly?
    Jul 2015
    Sydney, Australia
    G'day all,
    I was reading through the manuals for my Warn XD9000 winch which was installed into the genuine Nissan steel winch bullbar by the Nissan dealer as part of the N-Trek package.
    The manual states the winch rope should wind in onto the drum from under the drum, whereas on mine it winds in over the top of the drum. Looks like Nissan has installed the winch upside down, is this a normal install for the Nissan bullbar?
    Here's a picture of my winch in the bullbar.
    Note: the free spool lever is on the left and motor on the right side of the picture.
    Cheers,
    Nige
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    Yes, yes it is. The only way to fit them in one of these bars is to rotate the gearbox and flip them upside down. Your clutch leaver will now be on the drivers side and the motor on the passenger side. Cable will feed from the top of the drum.
  4. The Following 2 Users Say Thank You to Rock Trol For This Useful Post:
    ngchan (4th August 2015), Skitzyrex (4th August 2015)
    Jul 2015
    Sydney, Australia
    Thanks for confirming that Rock Trol.
    I guess I should also check the appropriate drain holes have been sealed and/or unsealed.
    Mar 2013
    NE Melbourne
    That's a good idea as some of the Warns have the holes. If it does and they have not rotated the motor then it will be on the top.
    Nov 2014
    Waikiki, WA
    Yes, make sure the drain holes are at the bottom and don't seal them.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
