Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: GU converting auto hubs to manual
    Quote Originally Posted by Rocket55 View Post
    You don't need to jack it up or pull the tyre off do you?? Just undo the 6 or 8 cap bolts and pull the hub off??
    That's correct
    Rocket55 (6th August 2015)
    Patrol Guru Rocket55's Avatar
    Sydney
    Well that really makes it a 10 minute job
    Cheers Rod
    My Build 2005 TD42TI
  5. #13
    461 Post(s)
    Yep. Just buy a cheap socket to fit the hex that locks the hub and weld a 3inch or so piece of flat bar to it on its side and you have a small tool to lock the hubs which you can keep in the door pocket.
  6. #14
    How's the serenity boots's Avatar
    Sep 2011
    Or just go to bunnings and get a plumbers pipe socket that fits. already has the bar with it.
  7. The Following User Says Thank You to boots For This Useful Post:
    mudski (7th August 2015)
  8. #15
    461 Post(s)
    Quote Originally Posted by boots View Post
    Or you could do that!
    boots (11th August 2015)
  10. #16
    Expert SpecialDave's Avatar
    Apr 2015
    Greensborough / sunshine / Aspendale. Kind of homeless at the mo
    Or cut the end off an old tyre wrench leaving a bit of bar... Bang done.. No welder or purchase required.
    02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
