6th August 2015, 07:23 AM
#11
The 747
Rocket55
You don't need to jack it up or pull the tyre off do you?? Just undo the 6 or 8 cap bolts and pull the hub off??
That's correct
The Following User Says Thank You to Winnie For This Useful Post:
Rocket55 (6th August 2015)
6th August 2015 07:23 AM
6th August 2015, 08:19 AM
#12
Patrol Guru
Well that really makes it a 10 minute job
Cheers Rod
My Build 2005 TD42TI
7th August 2015, 03:36 PM
#13
Yep. Just buy a cheap socket to fit the hex that locks the hub and weld a 3inch or so piece of flat bar to it on its side and you have a small tool to lock the hubs which you can keep in the door pocket.
7th August 2015, 05:03 PM
#14
How's the serenity
Or just go to bunnings and get a plumbers pipe socket that fits. already has the bar with it.
The Following User Says Thank You to boots For This Useful Post:
7th August 2015, 07:47 PM
#15
boots
Or you could do that!
11th August 2015, 02:10 AM
#16
Or cut the end off an old tyre wrench leaving a bit of bar... Bang done.. No welder or purchase required.
02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
