Results 1 to 5 of 5
Thread: Pajero wheels
    Jul 2015
    Pajero wheels
    Hi,
    I have a mate selling his pajero alloys off of his 2000ish Pajero.
    I currently run sunnys with 35's and I am looking at saving a little on economy and tyre wear for daily driving.
    Will the Pajero rims fit onto my 98 GU wagon?
    Thanks in Advance
    No way will they fit The 6 bolt pattern is the same but the centre circle will be too small
    I think the patrol has 110mm circle the Paj only 60MM if that, so no they wont fit
  4. The Following User Says Thank You to threedogs For This Useful Post:
    98GU4.5 (31st July 2015)
  5. #3
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    2000ish ?.
    If it is a NP model they wont fit because of the size of the hub. (as Threedogs says)
    If it is a NL Escape, or GL they have 15" and most likely the rim will hit on the brake caliper.
    If it is a NL GLS or Exceed they have 16" and you might be lucky.
    Was a CRD
  6. The Following User Says Thank You to ova50 For This Useful Post:
  7. #4
    Jul 2015
    Thanks guys for your help!!!
    I didn't think they would but was worth asking.
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    The ones with the big enough center still dont fit as the offset is wrong and it hits on the brake caliper. i have tried with alloys off a NJ
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
