Results 1 to 8 of 8
Thread: Wire Winch Cable
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Wire Winch Cable
    A question about the cable.
    Would it be good practice to let the cable out and rewind it at regular intervals?
    I don't use the winch often, but today I used it and haven't done so for about a year, and this prompted the question.
    Was a CRD
    330 Post(s)
    You should ensure you have lubricated your wire rope, if it's well lubricated it will be fine wrapped for an extended period.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    ova50 (28th July 2015)
  5. #3
    330 Post(s)
    Or get rid of it and swap it for synthetic rope.
  6. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Rossco (28th July 2015)
  7. #4
    Quote Originally Posted by ova50 View Post
    It definitely can't hurt, and would be good for the winch too.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #5
    Nov 2011
    What type of lubricant would one use?
    I would have thought that a lubricant would be more inclined to allow dust etc, to stick to the cable.
    Also, what are the advantages of using synthetic rope?
    Was a CRD
  10. #6
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    The advantages of synthetic rope are:
    1. Lighter and easier to handle
    2. Safer as it doesn't store as much energy. If it snaps it wont be as dangerous
    3. Stronger as long as you don't bounce off it
    4. Floats on water
    Disadvantages are:
    1. Higher maintenance. Need to keep clean, especially if grit gets in between the fibres (can cut it)
    2. UV can damage it over time
    3. Can be cut easily if winching over sharp rocks etc.
    2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
  11. The Following User Says Thank You to Rock Trol For This Useful Post:
  12. #7
    330 Post(s)
    Wire rope lubricant will be available at any machine shop or most decent tool shops. You could just use WD40 even. You want it to soak into the centre strands so it won't tust from the inside. The lubricant also stops strand friction and allows the rope to take tension without side wall strand friction.
    Lubricate and clean, respool under load.
  13. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    blocko05 (4th August 2015), ova50 (28th July 2015), Woof (29th July 2015)
  14. #8
    Nov 2011
    Thanks Rock Trol, Today I had the cable running over some sandstone rocks & garden beds dragging a couple of tree stumps from the yard to the front of the house. Chances are I would have damage a synthetic cable.
    Thanks for the advantages & Disadvantages, gives me something to ponder.
    Thanks Mudrunner, I will purchase some and give it a coating on the weekend.
    Was a CRD
