Results 11 to 20 of 29
Thread: EFS vs OME Shocks?
    Yeah on price I think Koni are $500 a corner,
    you would think $250 will buy a decent shocker for Aust conditions
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    I've got the Pedders Trak Ryder stuff on my Patrol and I got to admit it soaks bugger all up, it just tends to crash through everything. As funds permit they will be making an undignified exit...
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  4. The Following User Says Thank You to Rocket55 For This Useful Post:
    Rock Trol (27th July 2015)
  5. #13
    North brissy
    OME all the way for me.
    Im keeping an eye on availability of the new bp-51 shock arb have done. Its a 51mm bore remote res with compression and rebound adjustment. They look awesome as well.
  6. #14
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    Quote Originally Posted by Rocket55 View Post
    So its not just me. I wasn't impressed with them either when they were still working. That's two strikes against them. I think they are made by Gabriel for Pedders.
    2007 DX CRD Wagon - EFS 2" lift, BOSS Chassis Brace Kit, Steel Bull Bar, Runva 9500-Q winch, FyrLyt's, Rock Sliders, Rear bar with wheel and twin jerry carriers, Drawers, Fridge slide, dual battery, Red Arc BCDC 1220, Red Arc EGT/Boost gauge, Scangauge, Uniden UHF, Prodigy P2 brake controller, CC Intercooler, Pacemaker 3" zhaust, HPD Dawes, ECU Remap.
  7. #15
    Have you had a chance to look at the Terrain Tamer remote reservoir smoothie shock?
  8. #16
    North brissy
    Just had a quick look. They look ok. It is always good if you can have rebound adjustment as well as compression. They are a little smaller at 46mm bore compared to the ome but if valved correctly shouldnt be an issue.
  9. #17
    Thanks I have an opportunity to get a set fitted for free. not holding my breathe
    but hopefully get a reply this week or next.
  10. #18
    Mar 2013
    NE Melbourne
    Terrain Tamer could be another option. Built in same factory as efs (cofap) in Brazil. Anyone had exp with TT shocks. Unfortunately I can't wait for TD to get his and review them. Need to sort out soon.
  11. #19
    Mar 2013
    NE Melbourne
    I finally made the purchase today. After asking about the OME and EFS I went with the Terrain Tamer TGS SERIES EXPANDED BODY SHOCK ABSORBER.
    I looked on the web and most reviews where positive about the TT stuff. It's made by COFAP so would be same quality to EFS and TT have a good reputation with honouring warranty (3 year/100,000 km). It's a big bore gas shock (40mm bore, 20mm shaft) so I am hoping it will last the distance, at least the warranty period.
    I also had a look at the Terrain Tamer Pro series shockies and they do look good. They are about $400 a corner though so its similar to Koni RAIDs (but still cheaper). The TGS came in at $128 per corner with my 4WD club discount. For $514 all up if they are a half decent shock I will be happy. They certainly are big buggers though.
    Has anyone else used the big bore Terrain Tamer's?
    EDIT: I was checking part numbers on the net and the TT TGS shcks have the same part number as the Lovell's Gas Legend shocks.
  12. #20
    Mar 2013
    NE Melbourne
    Terrain Tamer Expanded body shocks fitted
    I had the Terrain Tamer Expanded body shocks fitted today. At first I thought they where valved a little soft but the car drove nicely and didn't wander over the road at rough/patched sections (60km/h). They are certainly valved softer than the OME Nitrochargers which had me a little worried that they might not work on the open road. I drove north out of Adelaide (Pt Wakefield Rd) and at 110 km/h the Patrol was steady as a rock. Changing lanes was no problem as the car was steady as well. Suspension felt supple over rough patches of the road and the car did not get pushed off its line.
    I then turned off onto a dirt road in Virginia and went for a drive at 80km/h. The car was steady as a rock even when going over large pot holes. Kept its line and absorbed all the bumps. I am very happy with the set up as this is a new feeling for me. The original springs where so stiff that the car skipped over a lot of bumps and I felt every one of them. Once the springs where swapped for EFS units the car absorbed much more but was very jittery and needed constant correction from the driver to keep it straight. Finally the car drives as it should!!
    As for the old shocks, the ARB Nitrochargers at the rear (152,000 km) where a little soft but still functioning. Happy with these. The Pedders Track Ryder foam cell units at the front where not destroyed as I suspected but still seemed to work OK (resistance both in and out). They are with Pedders at the moment getting tested. I suspect the new 120kg constant load springs at the front where just too much spring for the Pedders to handle.
    As for Terrain Tamer longevity? Time will tell. Reviews I have read on the web are very promising.
