Results 1 to 10 of 14
Thread: Removing snorkel
    Expert daz172's Avatar
    Nov 2013
    Removing snorkel
    Hey I need to change my snorkel over on my recently bought gq, but I can't get it off. I have taken all nuts off Inside wheel arch but it seems to b glued there or something, any tips on how I can remove it? I've pulled on it quite hard but worried if I pull any harder risk panel damage.
    461 Post(s)
    You have removed the pillar mount screws too i take it. As far as i know there is only the three nuts on the inside which you have undone. The previous owner might have added some double side tape or similar to help seal around the guard.
    175 Post(s)
    Depending on installer, they may have silliconed inside connections for a tighter seal ?
    Nov 2013
    Yeh the screws from the pillar are out , everything in bolted , it's defo on with some silicon or something, I'm thinking the only way to get it off is to try get a blade down there and try n cut it off but it's gonna do some serious paint damage , I'm hoping some1 might have a diff idea that doesn't involve any damage to anything
    461 Post(s)
    Have you got a heat gun? Maybe get some heat up there to see if it unsticks what ever is holding it.
    If its double sided tape the heat gun will help. Not sure on silicone though.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by daz172 View Post
    Can you get a wire down there and use it like a saw. May do less damage than a blade.
    Nov 2013
    Good thinking , I will try all of those ideas , thanx, I will let you know how I get on
    Nov 2013
    So I got snorkel off, b4 that had a moment where I realized I'm a real jackass lol , there was 1 bolt that I had missed last time , that was wat was holding it on lol and it was staring me right in the face lol, thanks for the help anyway
  10. The Following User Says Thank You to daz172 For This Useful Post:
    mudski (29th July 2015)
  11. #9
    LOL you get that on the big jobs, glad you finally got it removed
  12. #10
    Aug 2014
    Kingsley WA
    15 Post(s)
    Glad you found the bolt. You would have been there a while trying to saw through it with a wire like I suggested.
