Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Starting the GQ with old fuel
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Hi guys and girls
    As your all aware my GQ has been sitting in the driveway unloved for well over a year
    I'm in need to move it 2 allow easy access for some steel shelving for the garage which is getting delivered in the next few days.
    Should I empty whats in the tank and put a few fresh litres in just 2 move it or could I get away firing it up with the old stuff in, would doing this do any long term damage???
    Toddie
    cant see it doing any damage but may not run as sweetly as you would like.
    I take it its petrol?
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I don't specificly know about the QG, but assuming its petrol and carby if you get stale fuel in it you will need to flush the entire system and maybe clean the carby. Drain the fuel thats in it is you can and use as much new fuel as you can. if it fires let it run a bit of new fuel into it before shutting down again. We have poured old fuel on the floor and chucked a match in. It doesn't burn at all.
    Aug 2010
    17 Post(s)
    Petrol......EFI
    Start it and see what happens. Good limiter bash when cold will clear it out lol.
    If you don't wish
    to drain the tank,
    maybe put a half cup
    of metho in
    to break up any
    moisture.
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    Todd,
    If you cant get it going, do you want me to come up there and we can tow it to a new spot?
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
    Aug 2010
    17 Post(s)
    Quote Originally Posted by rkinsey View Post
    Todd,
    Should be right mate, I can get passed it but thought it would be a lot easier with it not in the way
    Battery is on charge, don't like my chances of if winding over anyway
    Thanks for the offer
  10. #9
    Aug 2010
    17 Post(s)
    Thanks all for the input, think I will just run the risk with old fuel if it kicks over
  11. #10
    Sep 2010
    Minchinbury
    No worries Todd.
    If you need a hand just sing out mate.
