Results 1 to 10 of 10
Thread: 97-8 GU Transmission in Drive
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    2 Post(s)
    Hi Guys, noticed when it's cold and when I put trans in Drive ,I find nothing is happening e.g. "not go forward" . then 10 to 15 seconds later it goes forward. after that the trans runs great , feeling strong and no slipping at all. when this happens when it's cold and can put trans in first gear and drive off normally, then back in to drive and runs fine. My ? is the ECU has a bug in it or fluid valve just about to go or something else. regards Alex
    p.s. I have changed the auto fluid and filter about a month ago.
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    What was it like before you changed the fluid and filter?
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by 4bye4 View Post
    I was thinking along similar lines. If the fluid was really contaminated, it might be sticking valve(s) in the valve body.
    Dismantling and cleaning a valve body is within the capability of anyone with mechanical skills.
    I did a thread on it with pics..
    John
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I actually noticed a noise in my auto after I did an oil change, changed it again to be sure. It was actually that my auto was already on the way out and needed a reco.
    Not saying that yours does, but getting it looked at by a shop will be best in the long run.
    I wanted mine to hold out for a few weeks as it was just before Xmas, it didn't and I destroyed the entire box. Cost double what it would of, had I gone sooner. Imo an auto playing silly buggers is not a happy camper, and is in need of some love.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. #5
    May 2012
    Morayfield, QLD
    13 Post(s)
    An auto on its way out would have a good amount of debris in the pan and that would have been noticed when the pan was dropped to do the filter.
    John
  7. #6
    Oct 2011
    Quote Originally Posted by jff45 View Post
    Mine didn't have a whole lot. Had a bit. But not in-excess. In saying that, the reason my auto died was due to the bearing in the torque converter failing allowing the fins?(plates? Whatever the things inside the tc are called) to wobble and then grind away at each other filling the cooling system with debris and super heating the box.
  8. #7
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by lhurley View Post
    yeppers, that will do it..............
    best case scenario is to take it to an Auto Tranny specialist
    they will give you worst case is could be - and also costs involved to rectify
    Tidy Whitey - 99 GU TD42Ti - Diesel Gas, (GUIV Turbo & Intercooler 8Lb boost), 33" Micky T's Baja MTZ's, Dual Batt's, Cargo Barrier, rear draws, HID Super Oscars, winch, Grinch & witch attached and more goodies to come
  9. #8
    May 2012
    Morayfield, QLD
    13 Post(s)
    Does the Power light on the mode switch flash to indicate any faults?
    John
  10. #9
    Nov 2011
    Rupanyup, 3388, VIC
    2 Post(s)
    Hi Guys, Sorry been oversea's ( USA) for the first time at 53 and love it . no fault lights , but the car still does it off and on . like this I can put it in second and drive off all fine then put it in drive down the road and it drive as it should , maybe a sticking valve !!!!!!!!! regards Alex
  11. #10
    May 2012
    Morayfield, QLD
    13 Post(s)
    Didn't someone mention possible sticking valve(s) in post #3 ?
    John
