13th July 2015, 11:23 PM
#21
Moderator
I expect that this accident has occurred as a result of joining 2 snatch straps together using a shackle to lengthen the recovery strap. One of the straps broke and the shackle became a missile. Not confirmed but I can't see another way that a shackle would become a missile.
Check out my Toy -->
Rogue Dung Beetle
13th July 2015 11:23 PM
14th July 2015, 03:16 AM
#22
the evil twin
Not quite right, Cobber...
The weakest link is the 8,000 Kg strap.
The 4.75t rating on a shackle is WLL for a lift.
The actual BS of a 4.75t rated shackle will be 18,000 Kg to 30,000 Kg depending on grade.
That's true but the WLL is what is used for safe operation. there is a safety margin incorporated in all the components but the rated WLL stamp on components is what we must go by, not the breaking strain.
98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
"GO YOU CROWS"
14th July 2015, 09:19 AM
#23
Chubba
WWL and SWL only apply to lifting,
Has anyone heard an update on this young guys condition.
Makes you wonder if you would be liable if a strap let go causing damage.
14th July 2015, 08:44 PM
#24
I am he, fear me
threedogs
What he said X2
Take a look at the size of an 8 ton rated shackle and you'll agree
Rated shackles also have a specified BS, it just isn't embossed on the shackle as that is not part of the Aust Standards is all.
That is also why the 1 ton rated shackles are acceptable to Authorities to attach safety chains when towing
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
Chubba (14th July 2015), threedogs (15th July 2015)
20th July 2015, 06:08 AM
#25
Steve
2011 Patrol Safari 4.8 (Fitek)
The Following 2 Users Say Thank You to Bulbous For This Useful Post:
Chubba (20th July 2015), Clunk (20th July 2015)
