Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Another recovery mishap....
    I expect that this accident has occurred as a result of joining 2 snatch straps together using a shackle to lengthen the recovery strap. One of the straps broke and the shackle became a missile. Not confirmed but I can't see another way that a shackle would become a missile.
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Not quite right, Cobber...
    The weakest link is the 8,000 Kg strap.
    The 4.75t rating on a shackle is WLL for a lift.
    The actual BS of a 4.75t rated shackle will be 18,000 Kg to 30,000 Kg depending on grade.
    That's true but the WLL is what is used for safe operation. there is a safety margin incorporated in all the components but the rated WLL stamp on components is what we must go by, not the breaking strain.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  4. #23
    Quote Originally Posted by Chubba View Post
    WWL and SWL only apply to lifting,
    Has anyone heard an update on this young guys condition.
    Makes you wonder if you would be liable if a strap let go causing damage.
    Chubba (14th July 2015)
  6. #24
    What he said X2
    Take a look at the size of an 8 ton rated shackle and you'll agree
    Rated shackles also have a specified BS, it just isn't embossed on the shackle as that is not part of the Aust Standards is all.
    That is also why the 1 ton rated shackles are acceptable to Authorities to attach safety chains when towing
  7. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Chubba (14th July 2015), threedogs (15th July 2015)
  8. #25
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  9. The Following 2 Users Say Thank You to Bulbous For This Useful Post:
    Chubba (20th July 2015), Clunk (20th July 2015)
