Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: GU ZD30 to TD42T Conversion....
    The master farter
    mudski's Avatar
    465 Post(s)
    Things are going quite slow at the moment with this. Bloody workshops taking their time! Lol
    Anyhow while I'm waiting and getting parts together I didn't think about the ECU. Anyone know if I need to change ECU's? From mine to an ECU from a GU with a TD42T of the same age? I'm thinking I might not need to as the loom is at Killa Custom getting the cut and shut done on the wiring so I assume they would make it so all the gauges can work...
    North brissy
    Shouldnt need an ecu.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (2nd July 2015)
  5. #3
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    Unless you're running an auto trans..
    John
  6. #4
    North brissy
    Quote Originally Posted by jff45 View Post
    This true but he isnt . Should only need a glow plug controller.
  7. #5
    Beginner JakeWild's Avatar
    Jun 2015
    Bupengary
    Mudski you should take some photos and post them up, I'd love to see the transformation.
  8. #6
    The master farter
    mudski's Avatar
    465 Post(s)
    Yeah, thats one thing i am yet to get. Jeff have said he is using an aftermarket controller. I am trying to find an oem unit, just so its "plug and pray".
  9. #7
    May 2012
    Morayfield, QLD
    13 Post(s)
    Just on the subject of gauges, from all the research I've done it appears that best practice is to use the temp sensor from the ZD motor if you're using the ZD temp gauge. Should swap straight over.
    Same applies for my TB.
    John
  10. #8
    The master farter
    mudski's Avatar
    465 Post(s)
    Funny you say that. I was just reading about this today too...
  11. #9
    May 2012
    Morayfield, QLD
    13 Post(s)
    What bellhousing are you using?
    John
  12. #10
    The master farter
    mudski's Avatar
    465 Post(s)
    One from a TD....
    First setback... Where I was getting the genuine head from, they are now out of stock! Now I have to pay nearly double for one.
